Superheterodyne wireless transceiver module from core electronics.
petercl14
Nov 6, 2020
7
Can I use the APF03 transmitter with a ht12e encoder IC and the RXB28 receiver with a ht12d decoder IC? If I have a logic high on an encoder data pin, I then need a logic high on the corresponding decoder data pin similarly for a logic low.
Can this be done with this module? How is it done?
Previously somebody asked how do you switch between 315mhz and 433mhz. What is the answer to this?
kellys_eye
Jun 25, 2010
6,512
So we have to download all the relevant datasheets (because you can't be bothered to even include them with your query) and read what the manufacturers say just so we can report this back to you?
Without being rude, why haven't you done this yourself?
We are always happy to help but we expect the OP to also be able to help themselves to a basic minimum extent.
Probably hundreds of videos on youtube with detailed how-to ........
Example......
