Proctologically Violated©®
- Jan 1, 1970
- 0
Awl--
I thought I had learned that conductors carried most of the electron flow on
their surface, but recently was informed that this would only be true at
high freq (skin effect). I disputed this via Coulombic forces, but then
realized that maybe Coulomb's law does not apply to flowing current in a
conductor--sumpn about hole current as well??
But indeed, a wire carrying current to a bulb is not charged the way a
capacitor is.
But THEN,
I just happened to be reading the 1996 edition of the NEC, and I noticed an
unusual entry: Nickel plated wire has 3-4 TIMES the current-carrying
capacity as regular copper wire.
At first brush, this seemed to support my initial assertion, that conductors
DO carry their charge on the surface.
But THEN, I realized that nickel (likely) has lower conductivity than
copper, so such an effect would appear odd even if current flow did tend
toward the surface.
Finally, I seem to remember the expression "current density" as a function
of cross-sectional area, which would suggest current is distributed
throughout the wire's cross section, not just on the surface.
So what's up w/ nickel plated wire???
In my 1920's house (Yonkers, NY), the service is solid #9 (!!! heavier than
10, but lighter than 8??), and it seems to be doing the job of #6 or #4
wire. In fact, I believe *all* the wiring in the house (cloth-covered #14)
is plated, and is also in very good shape--thank god. Splices are wire
nutted AND soldered, as well.
But back to the original topic:
At DC, or 60 hz, is current density uniform throughout the wire's cross
section? If not, what type of distribution does it have?
Why does Coulomb's law moot in a current carrying conductor?
TIA.
capacitor is.
But THEN,
toward the surface.
TIA.
