charles
- Jan 1, 1970
- 0
I wonder why, since electrical codes in North America
and Britain require a ground connection at each outlet;
computer power cords are 3 wire?
hot neutral ground
or, as we call it, Live, Neutral & Earth
hot neutral ground
Meanwhile, I'm still waiting for an explanation from w_ about how
surege protection inside that computer can work? Where is that
direct connection to earth ground, without which w_ says surge
protection is impossible? Does the computer have a mythical earth
ground inside? The answer is it doesn't. It is acting under exactly
the same limitations and uses the same components, typically MOVs to
do what a plug-in surge supressor does. w-'s answer to this is to
claim that electronics, appliances, etc do not use MOVs, a claim
previously smashed, because of course they do. Plus it really has
nothing much to do with the question anyway, because the computer,
appliance, etc still HAS NO DIRECT EARTH GROUND, without which w- says
protection is impossible.
What kind of ground rods? I prefer steel core, copper clad onesI even
have the special heavy hammer>
Look at poor w_tom starting his back-pedalling.
Back-pedalling, back-pedalling, back-pedalling.
Jitt said:I wonder why, since electrical codes in North America
I'm curous to know how surge suppression can work without a ground
(earth) of any sort.
w_tom said:People who are more than TV repairmen learn from their mistakes and
correct reasons for that failure. TV repairmen only fix defects -
never bother to learn how those failures can be avoided. Let's have
some fun. Let's reply using the same mockery and insult that Michael
uses. Except this post will be accurate about Michaels intelligence.
Timothy Daniels said:Does that mean a combination of w_tom's "whole house protection"
and individual "surge protectors" at those "critical devices"? That's
what I've always felt would be prudent - not a single method of
protection, but a combination.
|> |> For example, consider the high frequency issue. High frequency energy is
|> |> less common than low frequency energy. Partly this is because the chance
|> |> of a closer lightning strike is less than a more distant one. A strike
|> |> within 100 meters is only 1/8 as like as a strike outside of 100 meters
|> |> but within 300 meters. Some people then feel that they can dismiss high
|> |> frequency energy issues entirely.
|> | Francois Martzloff was the surge guru at the NIST and has many published
|> | papers on surges and suppression. In one of them he wrote:
|> | "From this first test, we can draw the conclusion (predictable, but too
|> | often not recognized in qualitative discussions of reflections in wiring
|> | systems) that it is not appropriate to apply classical transmission line
|> | concepts to wiring systems if the front of the wave is not shorter than
|> | the travel time of the impulse. For a 1.2/50 us impulse, this means that
|> | the line must be at least 200 m long before one can think in terms of
|> | classical transmission line behavior."
|> | Residential branch circuits aren't 200m.
|> | Your response: "Then he flubbed the experiment." In another case you
|> | have said Martzloff had a hidden agenda.
|> I addressed this one elsewhere. You seem to have misunderstood him.
|> He did not say that wiring systems do not exhibit transmission line
|> characteristics.
| If you had actually read the quote:
| "*it is not appropriate to apply classical transmission line concepts to
| wiring systems*"
| and "*this means that the line must be at least 200 m long before one
| can think in terms of classical transmission line behavior*."
| Repeating: "Residential branch circuits aren't 200m."
You are now taking what Martzloff said out of context. He _qualified_
what he said in terms of a statement conditional. Following the part
you just now quoted is "... if the front of the wave is not shorter than
the travel time of the impulse." Then he added "For a 1.2/50 us impulse,
this means that the line must be at least 200 m long before one can think
in terms of classical transmission line behavior."
Hint: what "if" means is that if the conditional is not met, then the
statement does not apply.
Martzloff's statement is actually correct. Your quoting of it is wrong.
I suspect your understanding of it is weak or maybe even wrong. I believe
you are misapplying it. Then when _my_ statement contradicts _your_
incorrect understanding, you somehow think *I* am contradicting him.
His statement is qualified for a specific slow impulse rise time that
corresponds to a lower frequency. He has NOT said (in what you quoted
in earlier posts here) that no surge can ever have a faster rise time.
He has NOT said that you cannot think in terms of transmission line
behaviour for faster rise times, even on shorter wiring/circuits.
|> | You claim lightning induced surges have rise times about a thousand
|> | times faster than accepted IEEE standards - which are experimentally
|> | derived.
|> So you are narrowing this statement to only induced surges?
| I intended "induced" meaning produced by including the most damaging -
| strikes to utility lines.
The most damaging strikes tend to be ones that are NOT induced. Do you
understand what induction and inductive coupling is?
Lightning does not have to directly strike the wire for there to be a
surge on it. That is induction when there is no direct strike. If the
strike _is_ directly on the wires, that's different (and has the exposure
of substantially more voltage/current).
w_tom said:Both of Bud's citations - guides for laymen
Bud quotes from Martzloff
selectively. Meanwhile this conclusion is so fundamental that
Martzloff makes it the first point in his IEEE paper:
Also are those 'scary pictures of plug-in protectors
Don said:----------------------------
Actually, you are showing some confusion. Phil is right in that he is
bringing out a point that normal lumped RLC circuit theory doesn't handle
because it essentially treats the speed of propagation of electrical signals
as if it were infinite- which isn't true.
2)Also, on energizing a line whether it is open or closed, there is a
current flow as the applied voltage "sees" the characteristic impedance of
the line (wire or whatever) so a current will flow-even on an open circuit-
until there is a modifying reflection from the termination. For a house the
distances are such that this may be of the order of 0.1-0.2 microsecond.
After all such reflections at terminations have ceased or are negligable,
conventional circuit theory is applicable.
In these situations, you are dealing with wave propagation rather than
conventional circuit theory.
This is the regime that is of interest in considering "surge protectors"
As to the advantage of "whole house" vs local surge protection, "whole house
protection depends on distances to all "protected" items being small.
Mike said:Yes, but the environment in which the protected dwelling is situated
should also be taken into account. For example, a house in Florida,
with its overhead power lines and frequent thunderstorms, would be a
more likely candidate for a combined approach to surge protection.
On the other hand, installing Florida-levels of protection in a house in
the UK with its infrequent storms, reliable underground power supply and
a decent electrical system with properly earthed sockets, would be a
waste of money.
| The last standards for simulating typical surge waveforms I have seen
| (IEEE) were
| 1.2 us rise time, 50 us duration
| 8 us rise time, 20 us duration
| a ring wave with a frequency about 100kHz.
So now you are saying these figures represent a typical surge waveform,
as opposed to the worst case waveform you said a long time ago.
What does the "/" mean in that case, anyway? I never got to ask you that
before. Does it mean "divide 1.2 by 50"?
| Previously you said Martzloff "flubbed the experiment".
I remember that. You were telling me about some information he had
obtained from some experiment.
| Now you agree with Martzloff that branch circuit must be 200m for
| transmission line behavior with 1.2 microsecond rise time.
That's not a result of an experiment.
I'm not so sure the exact distance
is 200m for that exact rise time. But that is a subjective thing.
| You say that doesn't apply because surges are faster. Martzloff uses 1.2
| us because that is a standard rise time for surges produced by lightning
| as defined in IEEE standards.
Martzloff did not say that was a defined standard in the statement you
quoted. He just used it as an example to come up with the 200m figure.
| w_' professional engineer source says 8 micoseconds with most of the
| spectrum under 100kHz.
Even with 1 nanosecond rise time, most of the energy will be present in
the spectrum below 100 kHz. That means nothing when the surge is strong
enough to have energy above some frequency that is relevant to the whole
system involved that can do damage. That frequency might be 100 Mhz for
some thing, and 1 GHz for other things.
| You still have *no sources that support your belief* that risetimes are
| far faster.
I have experience and observation for that. I need no more.
