Surge Pulse Clamping with Ceramic Capacitors
K
Klaus Kragelund
Klaus said:
Another idea is to use the Bourns CDSOT23-SM712, specifically designet
for surge protection for RS485 devices, but add ceramic caps in series
with each line connection so it can tolerate 30V without creating
wonderful smoke, but will be able to clamp surge pulses without
affecting the high speed bus.
Regards
Klaus
Like this:
www.electronicsdesign.dk/tmp/RS485_cap_protection.pdf
But that would not protect against a hard 30VDC applied because an
installer miswired something. It could cause your RS485 chip to go PHUT
unless it has internal protection against this.
The RS485 IC has +/-60V protection rating, so its ok
Which one do you use? The ones on mine (clients's choice) have abs max
ratings of -8V to +12V, and no internal circuitry given.
LTC2862, can take 60V indefinitely, but you need to add clamping
circuit to the VDD node since it will dump current into that node if
it is in transmit mode and is subjected to back fed voltage.
Wow, that sure is the Rolls-Royce of RS485 chips. With a corresponding
price tag :)
But isn't that bleed-through only an issue if the ground of the LTC2862
has come off? Otherwise this would really be a problem because you'd
just have moved the dissipation from one place to another. I think the
only real protection for 30V continuously is some sort of cut-off,
whether inside or outside a chip. At least a partial one where the
current becomes very small.
When the device is in transmit mode, it has no way of knowing if an appliedvoltage is just a load or a fault. So it has current limit on the outputs and if sourcing into the VDD is detected, the driver is shut off. If 5V is supplied to the device externally, only the current limit is active and thecurrent is steered to the GND or VDD rail.
Regards
Klaus
K
Klaus Kragelund
What's the source impedance of that 1KV pulse? Maybe a transzorb can
handle the energy.
Its 40ohms, 1kV, 8/20us, so approx 20A pulse.
If you use a diode, be careful about the diode's forward recovery
time.
Sometimes it works to use a series resistor to limit the current,
instead of sinking all that impulse energy.
We have no room for it, 0402 and 0603 resistors is only option a´nd they really cannot handle much
Cheers
Klaus
John Devereux
Regards
Klaus
Like this:
price tag :)
TI do some fault protected ones, probably going to use some in a
redesign, where they keep blowing up the tranceiver.
<http://www.ti.com/lsds/ti/interface/rs-485-products.page>
<http://www.ti.com/product/sn65hvd1781>
Joerg
LTC2862
you'd
the
applied voltage is just a load or a fault. So it has current limit on
current limit is active and the current is steered to the GND or VDD
rail.
They probably should have built in an internal VDD run-up trigger that
then limits the current to zero. If it doesn't let go of the bus at that
point that could present a problem.
Joerg
price tag :)
Those are nice but one should read the disclaimers on page 12. Doesn't
sound like 100% useful protection to me.
Joerg
I really do not like PTC fuses but they might be the only option here.
John Devereux
price tag :)
True, but in fact 30V is enough for my application. Basically they keep
connecting/shorting the data lines to a nominal 24VDC.
K
Klaus Kragelund
Klaus said:
LTC2862
you'd
the
It actually has that function, AFAIR the trigger level is 1-200 mV above rail
Regards
Klaus
K
Klaus Kragelund
You have room for power diodes and capacitors but not for resistors?
To drive the bus the impedance towards the line must be low, so the impedance is below 5 ohms anyway, and that wont matter much against a 20A pulse. Aresistor that takes 2000W for 20us is not easy to come by
A standard 1206 shows 10W for 10us...
Regards
Klaus
Joerg
LTC2862
you'd
the
rail.
Interesting. Then you shouldn't have an issue with the rail floating up,
or you only need a very light load on the rail.
K
Klaus Kragelund
LTC2862
you'd
the
rail.
The maximum rail current is 80mA as defines in the datasheet, so the shunt regulator on the VDD rail must be able to sink this current
Regards
Klaus
Joerg
Klaus said:
the LTC2862 has come off? Otherwise this would really be a
problem because you'd just have moved the dissipation from
one place to another. I think the only real protection for
30V continuously is some sort of cut-off, whether inside or
outside a chip. At least a partial one where the current
becomes very small.
if an applied voltage is just a load or a fault. So it has
trigger that then limits the current to zero. If it doesn't let
go of the bus at that point that could present a problem.
mV above rail
floating up,
Just took a look at the datasheet again. I can't see that 200mV
above-rail cut off anywhere. Just an entry on page 3 that the thing can
sink up to 250mA into its supply. Because it says -60V to 60V in the
conditions box. Then a graph on page 7 that says something different.
I'd really contact LTC app support before using it, this datasheet looks
too ambiguous to me.
K
Klaus Kragelund
becomes very small.
mV above rail
floating up,
The 200mV number is a number from the engineers from Linear Technology, I contacted them since I saw the same thing you did.
From LTC:
Qoute
The answers to the questions regarding LT2862 is the following.
In receive and shutdown, the lines are high ohmic, 112k, meaning no problem if connected forever to +/-60V.
In transmit mode there is the graph showing pin current for output low and output high as function of voltage, assume worst case 1.66 x nominal.
The 80mA worst case current going to Vcc is happening at the narrow spike (output high, a few volts positive, peaking at about 60mA typ) in diagram below, at higher voltages the current goes to GND.
Unqoute
Cheers
Klaus
Joerg
Klaus said:
ground of the LTC2862 has come off? Otherwise this
would really be a problem because you'd just have moved
of cut-off, whether inside or outside a chip. At least
a partial one where the current becomes very small.
knowing if an applied voltage is just a load or a fault.
VDD rail.
let go of the bus at that point that could present a
problem.
1-200 mV above rail
floating up, or you only need a very light load on the rail.
current
can
the
different.
looks
From LTC:
Qoute
The answers to the questions regarding LT2862 is the following. In
problem if connected forever to +/-60V. In transmit mode there is the
of voltage, assume worst case 1.66 x nominal. The 80mA worst case
Unqoute
Assuming they mean the graph on page 7, middle right:
http://www.linear.com/docs/40761
That shows that if someone would apply +30V it'll still draw 50mA times
1.66 for worst case. That's 2.5 watts worst case ... phsssst ... *POOF*
.... I'd say then it's not safe.
It says it has thermal shutdown that disables the driver but from the
way I understand it that all means you'd still have a big fat current
dumping into the logic rail. Which would need to go somewhere so it
won't float up.
K
Klaus Kragelund
VDD rail.
problem.
1-200 mV above rail
current
can
the
different.
looks
From LTC:
That's the correct figure, but only valid if the device is in transmit mode, during receive mode the currents are zero.
The only way the device can be in transmit mode is if a telegram is send to it and that's impossible if 30V DC is applied to the line. So no phssssst...... *POOF* :)
Anyway, the discussion about the DC is a little theoretical, since if 30V DC is applied to the line, what happens to all those other slaves and the master that has no DC protection? collective phssssst...... *POOF* ;-)
Regards
Klaus
Joerg
think the only real protection for 30V continuously
is some sort of cut-off, whether inside or outside
becomes very small.
the current limit is active and the current is
run-up trigger that then limits the current to zero. If
it doesn't let go of the bus at that point that could
present a problem.
1-200 mV above rail
rail.
this current
thing can sink up to 250mA into its supply. Because it says
-60V to 60V in the conditions box. Then a graph on page 7 that
says something different. I'd really contact LTC app support
before using it, this datasheet looks too ambiguous to me.
From LTC: Qoute The answers to the questions regarding LT2862 is
the following. In receive and shutdown, the lines are high ohmic,
112k, meaning no problem if connected forever to +/-60V. In
1.66 x nominal. The 80mA worst case current going to Vcc is
the current goes to GND. Unqoute
times
*POOF*
Sure, if there is this sort of "natural" protection via protocol and
your system will never be sending unsolicited half-hour sermons (or be
the communications initiator) then you should be safe.
*POOF* ;-)
Yeah but ... imagine what the end customer would notice: "Now why is it
that every time things go kablouie only the device from the Vikings
survives?" :)
becomes very small.
present a problem.
 1-200 mV above rail
rail.
this current
times
*POOF*
you could put some form of inhibit on tx_enable when you see the
fault condition
-Lasse
