switch with indicator light
Pharaday
Jan 18, 2016
138
OK so this eels like a dumb questionn but I took a SPST with an indicator light that is set up so that when the switch is on, it also completes the circuit on the indicator LED. The - wire on the indicator LED is connected to one prong and there is a 3rd prong for the indicator LED's + wire. The indicator LED runs on a separate little battery. I wanna is use this on an ebike but to do that, I must connect a "power on" wire to the system + wire. If you put your multimeter probes on the "power on" wire and the system + wire, you would read system voltage. Can I use that same set of prongs to carry the - wire that powers the indicator LED? So, would I not burn out the LED by somehow giving it the full system voltage (48V)?
Martaine2005
May 12, 2015
5,318
The illuminated switch will have max voltage and max amps printed on it (hopefully).
The terminals should be numbered 1,2 and 3 or A,B and C (hopefully).
The internal LED will have a current limiting resistor for the given Maximums.
I don't see what a traffic light has to do with anything!
Upload a picture or link of your switch.
Martin
