Switching circuit making help?
Shyamal796
Mar 19, 2012
32
I need such kind of Flip-flop ic or any othe ic, in which i give always input 1 after a certain period and get the output sequentially 0 and 1.
Is it possible to make this by using T Flip-flop?
Help
Shyamal796
Mar 19, 2012
32
I find one solution using T flip-flop. But have one problem?
14,315
7 is an output. Do not connect it to GND or VCC.
1 and 5 are low active inputs for set and reset. If you do not wan to use these functions, tie these inputs to VCC (pull up). Use a series resistor (e.g. 1kOhm) for pull up, not a direct connection to VCC.
Note: a direct connection will work in almost all cases, but using a series resistor (pull up) is good practice. It allows you for example to make a connection to GND for test purposes with a piece of wire without short-circuitingb the power supply.
Harald
Shyamal796
Mar 19, 2012
32
Thanks Mr. Harald.
I was confused to connect the pin 1 & 5. But now i will connect this pin to +Vcc with resistor (1K).
My solved circuit is that i want .......
gorgon
Jun 6, 2011
603
You should always use a resistor for pullups on TTL and TTLLS logic inputs. This is because the input is drawing current due to the construction of the chip, and you limit this current with a 1k resistor. Never connect TTL inputs direct to Vcc.
TOK ;)
