Eeyore
- Jan 1, 1970
- 0
MooseFET said:20 * 5 / sqrt(2) = 70W
20V pk = 14.14V rms - squared = 200 divide by 4 = 50 W rms. No that bit's OK.
Graham
MooseFET said:Transformers aren't all that expensive. Going a bit over designed on
the transformer will make it run cool.
There is another issue that has been ignored all the way through these
arguments. The actual mains voltage can be 10% either way of the
nominal. The design needs to be done at the two extremes if you want
it to produce the rated power at the low line case and survive the
normal high line case. A thermal shutdown is a very good idea here
too.
But for audio the average power is much lower, at least for music,
so 100VA would be just fine.
Agreed.
nominal.
too.
"MooseFET"
** Huh ????????
Why the root 2 ??
Peak power = double "watts rms" - you dumb asshole.
..... Phil
Jan said:Thermal shutdown is a very clever idea,
that protect against those 100% sine wave tests![]()
I must say that those toroids hardly ever get really hot in audio amps....
And he should not be too pedantic,
the difference in volume between 45 W and 50 W is not that big.
Fred said:The chip has a 138 peak output capability.
I design mine to survive sinewave tests into the rated load ! Why ? Because
highly compressed 'rave' DJ music exhibits almost exactly the same dissipation.
Jan said:I design mine to survive sinewave tests into the rated load ! Why ? Because
I duno where everybody lives, but I am sure if I run the Chinese 2x 100W for a whole
afternoon, then either all the young ones come party here, or somebody will complain.
Or both![]()
DJs don't !
The average Chinese amp is crap down to its very foundations.
Graham
Jan said:DJs don't !
That Olympic opening and closing was pretty impressive from a technical POV.
They have a space walk planned for the coming month.
And I know some other Chinese products that impress me.
Face it, it is all over![]()
They have too many drugs in them to notice.
Playing light orchestral or whatever is a piece of shit. Any sodding smp can do that.
No it isn't. We just need to pick ourselves up and execute people like Thatcher and the
Bushes. It's called a 'revolution'.
Graham
I usually stop or reduce volume when I smell voice coil.
Or both![]()
Fred said:Now I can do some realistic ripple studies.
On a sunny day (Wed, 17 Sep 2008 06:52:49 -0700 (PDT)) it happened MooseFET [....]The design needs to be done at the two extremes if you want
too.
20V pk = 14.14V rms - squared = 200 divide by 4 = 50 W rms. No thatbit's OK.
It happens.
Graham
a temp controlled fan, stereo, all in a nice 19 inch rack, with separate volume controls
for left and right, with clipping warning indicator LEDs, with power switch, cinch AND XLR
connectors on the back....
So here are some pictures from the PA3000 inside, the transformer is 220VA.
Discrete is simpleand no, it is not MOSFETs, the power transistors seem to be
2SA1943 (PNP) and 2SC5200 (NPN).
