sxc 1901F from a micronta multimeter 22-193
alpibucky
Does anybody have a datasheet of this IC.
My 22-193 readings are wrong and the BATT indicator appears
continuously, but the batteries are good.
With my kind regards,
Alpibucky
ehsjr
alpibucky said:
Alpibucky
Could it be a dual comparator, NJM2903D ?
The RS parts list seems to indicate that as a possibility.
If the chip is a comparator, the circuit is likely dividing
the battery voltage, and comparing the result to a reference.
That said, examine the battery connections, and circuit path
from the battery to the PCB's. More likely the problem
is in the path somewhere, than a defective IC.
Ed
F
Franc Zabkar
AFAICT, the SXC1901F was manufactured by Seiko Instruments.
FWIW, the following document lists a service manual, cat# 10824373, NP
Part # MS2200193.
Parts List for 220-0193 AUTORANGING FOLDING DVM:
http://support.radioshack.com/support_meters/doc21/21609.htm
- Franc Zabkar
Shaun
once those Radio Shack multimeters go astray, that is usually it for it. Go
buy a fluke.
Shaun
"alpibucky" wrote in message
Alpibucky
