Synchronizing T-flops?
Jim Thompson
The problem...
Running from a 2.2 GHz clock and squeezing power, I'm using T-flops
(toggle-flops).
I DIV2 on positive edge to get 1.1GHz
I also DIV2 on negative edge to get 1.1GHz but shifted +/- 90°
Continuing with the dividing I get down also to...
137.5MHz
and 137.5MHz, angle +/- 90
I want to mix the 1.1GHz and 137.5MHz signals to get either 1.2375GHz
or 962.5MHz in a image-reject mixer
The snag...
The sum/difference depends on phasing of each component, but, since
each of the final components started out from toggle flops the final
sign of the 90° is unknown.
Anyone have clever ideas to determine whether each component is + or -
90° ??
If I can determine phase I can flip to the correct phase thru a PECL
inverter.
If I can solve this then the system can simply call for high or low
sideband and be assured its the right one.
Right now it's random :-(
This is on an ASIC, so I must DESIGN the circuit, NOT buy something
off-the-shelf which consumes more power than this whole WiFi chip.
...Jim Thompson
John Larkin
The problem...
(toggle-flops).
137.5MHz
The snag...
90° ??
inverter.
...Jim Thompson
You need some d-flops.
John
Jim Thompson
John
At 2.2GHz the process was failing some corners when I tried starting
with D's
...Jim Thompson
John Larkin
with D's
...Jim Thompson
You could do the dual t-flops to get to 1.1G, like you propose, then
use a d-flop running at 1.1 to determine if the t's are in the desired
phase sequence or not. Use that info to flip the phase of the 137.5 to
select the proper mixer output freq.
Or something.
How much image rejection do you need? Keeping close to 90 degrees at
1.1G won't be easy. 1 degree is just a few ps.
John
Z
Zak
Test it using some test tone, see what the phase is, and act
accordingly? This might need firmware support.
Or: use a delay (RC?) and a transmission gate to figure out the phase.
Thomas
Rene Tschaggelar
Jim said:
The problem...
(toggle-flops).
137.5MHz
The snag...
90° ??
AND, AND Not
inverter.
.. flip the phase with an inverter ?
That stuff is not that fast. If the inverter is just
introducing 100ps delay, that amounts to a phase error
of some degrees.
Rene
F
Fred Bartoli
Jim Thompson said:
The problem...
(toggle-flops).
137.5MHz
The snag...
90° ??
inverter.
Why don't you divide down to 550MHz with your T flops (only one chain), then
divide by 4 with a ring counter.
Only 2 T flops, and 2 D flops that run at low frequency.
You know which output is which phase and this is probably even lower power
than 2 dividers chains.
Chris Cheney
In addition to the two Ts, you need one D f/f (at 1.1 GHz) to determine the
phase to control the PECL inverter that you (Jim) originally proposed. 137.5
MHz similarly.
By way of more explanation, take the reference (0 deg) 1.1 GHz signal to the
D-clock input, and the + or - 90 signal to the D-input. If the 90 leads then
the D output will be 1 and if it lags it will be 0.
HTH
Jim Thompson
MHz similarly.
HTH
Aha! I think that will work. I'm thinking that, since I'm producing
SSB, I only need to _know_ the 1.1GHz and 137.5MHz phase, and flip
ONLY the 137.5MHz accordingly, to get a known sum or difference (high
or low sideband).
In case anyone is pondering... I, the Great God of Analog, made a
blooper...
Designed a chip, everything works perfectly, except... on power-up,
it's random as to which side band it's on :-(
However, since there's already a switch in the logic to pick low or
high sideband, I'll just add Chris' D-flop and then some logic to the
switch path.
Thanks!
...Jim Thompson
John Larkin
switch path.
I thought it was my flipflop.
John
Jim Thompson
John
You were too vague for El Denso to understand... us analog guys need
pictures ;-)
...Jim Thompson
John Fields
or low sideband).
blooper...
switch path.
So,
"This is on an ASIC, so I must DESIGN the circuit,NOT buy something
off-the-shelf which consumes more power than this whole WiFi chip."
should really have read more like:
"This is on an ASIC, and I don't know how to DESIGN the circuit, so
any FREE help would be appreciated."
Andy
Or something.
John
Another variation: use just 1 T-flop flopping on the negative edge of
the input clock, and feed its output to the D-flop latching on the
positive edge of the input clock. That way the D-flop's output will
always lag 90 degrees the T-flop's one. This would save a flop, but
might have the inconvenience of non-equal propagation delays of the T-
and D-flops.
-- Andy
James Beck
So,
John Fields
Professional Circuit Designer
Jeez, take a chill pill.
More like, he needed to bounce a few ideas around, and USENET is a free
and easy way to do that. I guess you have NEVER used any info you have
found here, you just hang out to make fun of the vast unwashed......
Oh, I guess I missed the "Professional Circuit Designer ", never mind.
Jim
John Larkin
pictures ;-)
...Jim Thompson
Well, I just sort of figured that there aren't a whole lot of
different ways to connect two signals to the inputs of a d-type
flipflop.
John
Lasse Langwadt Christensen
Andy said:
John Larkin wrote:
snip
and D-flops.
yep, keeping the two paths the same is probably a good idea,
that's the nice part about doing it by sampling I with Q to get the
lead/lag, instead of changing the I/Q generation scheme which it
sounds like has been verified in silicon
-Lasse
Jim Thompson
Jim
Mr. Beck, Don't let John Fields upset you. He is required to keep
spouting absurd inanities in order to maintain his status as resident
village idiot ;-)
...Jim Thompson
John Fields
Don't like the attitude, huh? Too bad.
Don't like the dotsig, huh? Also too bad.
Think you've got something to say? You don't, but dumbfucks like you
don't seem to be able to come to that realization without some kind of
outside help, so here it is:
You're an ignorant son of a bitch and you have nothing important to
contribute to this group (sed). That is, out of nine posts only three
were on topic (one only marginally) and the rest were all off-topic,
inane garbage. Why don't you take a hike over to alt.cocksuckers,
where I'm sure you'll find a more appreciative audience.
John Larkin
Dang, John, you and Chris are _quick!_
I was gonna answer this one! :)
Well, free engineering consulting is a very competitive business.
John
