Meindert Sprang
- Jan 1, 1970
- 0
I have a problem synchronizing two AD9952 DDS chips.
Both run from the same clock source (40MHz) and have the PLL multiplier at
10x. Both have the ClrAccumulator bit set, so when both DDS's are loaded
with new frequency data (the same), a trigger on the IO_UPDATE signal (both
connected together on a mpu IO pin), they are supposed to update the
internal registers and at the same time clear the phase accumulator. Still,
I have a phase difference between both DDS outputs which is, funny enough, 2
clock cycles (5ns), either leading or lagging or, coincidentally 0.
I have done the same trick before with two AD9854, which didn't even have a
ClrAccumulator feature, but resetting them once at the same time did the
trick.
These AD9952's even have a master/slave mode which is supposed to keep them
synchronised, but this doesn't work either.
The PCB is laid out as 4 layer, power and ground in the middle, separate
digital and analog supplies. All by the book, as as far as I know.
Funny thing is, and it might be a hint like a sledgehammer to others, is
that when the slave DDS has it's sync output enabled, the phase difference
is changing continuously while when this output is disable, it is contstant.
So the whole problem might still be caused by some unwanted crosstalk on
some signal trace.
Suggestions anyone?
Meindert
trick.
some signal trace.
Suggestions anyone?
Meindert
