synthesizer problems
[email protected]
May 29, 2007
6
hello everybody. so i am building a synth using a bunch of 555 astable circuits with an octave up feature that works like this: i use  a cd4066 quad bilateral switch to connect a second timing resistor of the same value as the one in the astable circuit when the control pin is at logic 1. i tried te circuit without the timing resistor and it worked fine, but then i tried it with the 4066 and the second resistor, and for some reason, even when the second resistor isnt connected in parallel, it effects the astable circuit.  i think there may be some leakage, or just something i dont know about the 4066, but i could really use some help. thanks, i appreciate it.
audioguru2
Apr 6, 2004
12,026
You forgot to attach your schematic so we don't know how the 4066 is connected and is powered.
MP1
Dec 7, 2003
3,399
Topic moved. Posted in wrong forum.
Projects Q/A is reserved for discussion of projects in this site's project section.
MP
quincy
Apr 16, 2007
44
drawing it would be tedious, but a good way
if your more computery, you can do it in paint
either way, id like to see it, because ive been looking for a simple audio oscillator cicuit myself
[email protected]
May 29, 2007
6
yeah, this i sreally simple if you dont have the whole octave-up thing goin on. its just  abunch of 555 astables w/ their outputs connected via a diode to a 741 summing circuit, that also knocks off  the harmonics. then just connect the 741's output to a 8 _()_ speaker decoupled with a 1 uF cap.
