Tail lights help
SubaruAmbassador
Feb 5, 2023
5
Hello everyone.
I'm currently trying to make some tail lights for the car and am trying to find good resources on how to power my idea properly if its even possible. I'm very new to all this pardon my ignorance.
Image 1 is the lights i put together as they are now.
I would like to change the blinker and reverse to a total of twelve 3v led filament tubes.
Image 2 is an idea just mapping with yarn.
I guess my question is, does anyone know of a semi easy to digest source of info to learn about converting the power, resistors, not going over the MA.
when i did the first setup they gave me a sheet on those individual leds and if i put blank in a row of this color i need blank resistor. so easy to make but i didn't learn anything.
kellys_eye
Jun 25, 2010
6,512
Best check with your local regulations as to your lights. They usually have to meet with regulations pertaining to light levels and beam spread so you can't just put 'any old thing' in its place.
If you're using LED tape (seems like) then you don't need resistors as the tape includes them - all you do is use LED tape of the right colour and apply 12V (or whatever they're rated at).
SubaruAmbassador
Feb 5, 2023
5
these are the tubes they are very thin. I orderd one to check them out and it didn't look to have resistors due to the size.
  • 5509_Web.pdf
SubaruAmbassador
Feb 5, 2023
5
Hello everyone.
here this is a better representation. is it possible to make this work?
kellys_eye
Jun 25, 2010
6,512
I don't think there's any way those 'tubes' will deliver enough light to satisfy the rules - one way ticket to a traffic infringement....
But.... it's your licence at stake, not mine. Those devices will require a resistor of approximately 560 ohms to work at 12V.
SubaruAmbassador
Feb 5, 2023
5
I got one to test and they are surprisingly brighter than it seems on camera. six would be plenty bright for a blinker. definitely brighter than an oem bulb. it should be a bit dimmer than the 60 leds i have in it now. but I'm alright with that as they don't need to be that bright.
SubaruAmbassador
Feb 5, 2023
5
sweet I'll do a test at 560 ohms and post a pic of it. thank you for taking the time.
