TC13B1-T heated blanket controller testing help
Jeremy Ridler
Apr 12, 2014
The Controller Led Lights Up Red But You Can Not Turn It On Or Increase The Heat Setting I Opened It Up And The Fuse On The Power In Side Is Good What Should I Test Next? Thank You For Your Help I Am New To This forum
If the electric blanket doesn't heat up, and if it's a simple switched arrangement, then the blanket has a fault.
Post some photos of the controller so we know what we're talking about. Otherwise we can't really comment (which is why we haven't)
Jeremy Ridler
Apr 12, 2014
Her are some photos of the board. I did ohm out the blanket and it has no breaks in it. I also tried the controller on another blanket we have and it did not work either.
Jagtech
Feb 22, 2014
43
The majority of failures with these items is a break in the cable where it enters the strain releif on the remote. Do a continuity check of each conductor in the cable before tearing into the electronics. Be sure to disconnect from the blanket when doing the test.
Electric Al
Jan 16, 2014
85
Her Are Some Photos Of The Board. I Did Ohm Out The Blanket And It Has No Brakes In It I Also Reyes The Controller On Another Blanket We Have And It Did Not Work Either.
If your blanket has no Brakes , how do you stop it from rolling down the hill ! o_O
Sorry ! I couldn't resist !
iT mAY bE tHE mOSFET.
