TDA8932 BT audio amp board power up
Azuro
Aug 1, 2017
Hi folks,
I tried to power up my TDA8932 bluetoith audio amp board but no succes. can you please help?
I connected a bluetooth cable and pluged it in my pc's usb port, but it was repeatedly flashing and my phone didnt find it. See photos attached.
I presume you mean USB cable; Bluetooth is wireless!
I found that board on Ebay, it requires 10 to 18V power. It is not surprising it does not work on. 5V USB port.
Azuro
Aug 1, 2017
Oh, I was presuming that, but needed confirmation from a more wiser person! Thank you very much Bob!
73's de Edd
Aug 21, 2015
3,730
Sir Azuro . . . . .
Megaditto . . .also . . . . on . . . .that aspect of
I connected a bluetooth cable . . . .
HOW . . . you do dat ?
As I can only see the foil patterned, ,receive antenna built on the board, that is being just adjunct to C7 surface mount capacitor.
Then there is only the central power connector and output speaker connections on either side of it.
73's de Edd .
14,487
Bob, it is BT you can even see the antenna on the input end of the board
@Azuro so I assume you have the matching BT (Bluetooth) transmitter board for this unit ?
I didn't say there was no bluetooth, just thst bluetooth does not use a cable.
I am guessing he plugged it in to a USB port for power, and 5V is not enoigh since itrequires 10.
