Tektronix 2245; need help with dead PSU
Alfred Green
Greetings,
My 2245 'scope recently died, with no outputs from the psu. The input
cct seems ok with ~150vdc across the filter cap, but I'm having a hard
time tracing the voltages any further without a schematic.
Does anyone have such a thing, and/or tips on what to be looking for?
In case there are different versions, the psu board has a 1986 date
code and uses a MC34060 pwm chip.
All comments welcome,
Alf in Scottsdale, AZ
[email protected]
Jim Yanik
[email protected] (Alfred Green) wrote in
Greetings,
[email protected]
ISTR that the 2245 service manual has schematics for the PS.
Ebay or big-list.com may turn up a manual.
And you can download a datasheet for the Motorola MC34060 IC probably at
the Motorola website.
You can ohm the switcher FET (open?)and any rectifier diodes(short?),check
the electrolytics with an ESR meter.
Techie
I might be able to help.
i have a manual for something like this.
might just be the same one.
will let you know later.
Alfred Green
I spoke to someone at Tektronix and he confirmed that the service manual
does include the schematics. They no longer have anything available however.
A net search has failed to uncover one either so far. I have found one for
the 2246; I wonder if it used the same psu as the 2245.
I have that info. Checking the vcc wrt the ground pin shows the voltage
varying from 0 to +5v; lower than I was expecting and I'm puzzled why it
would be changing.
The input switcher is an IRF830 which I think is enhancement mode, so I cant
really check that without supplying gate voltage. The diodes and caps seem
ok, but testing them in-circuit could be misleading.
I'll keep on exploring, and I appreciate the comments.
Rgds, Alf
Scottsdale AZ
[email protected]
Jim Yanik
manual does include the schematics. They no longer have anything
available however. A net search has failed to uncover one either so
far. I have found one for the 2246; I wonder if it used the same psu
as the 2245.
Yes,it does.(I coulda told you TEK would nothave the manual;the 224X series
has been 'obsolete',or past the 'Long Term Support Period' for several
years now.)
voltage varying from 0 to +5v; lower than I was expecting and I'm
puzzled why it would be changing.
The 'housekeeping' supply for the IC is started by a cap charged by a
resistor from the rectified line V supply.The cap charges,the IC tries to
start,but the xfmr winding that maintains the 'houskeeping' supply cannot
supply current,perhaps because the switcher FET is open.
I cant really check that without supplying gate voltage. The diodes
and caps seem ok, but testing them in-circuit could be misleading.
That ESR meter (Dick Smith meter!!) is invaluable for testing in-circuit
electrolytics,especially for switcher supplies.
Alfred Green
Jim Yanik said:
Yes,it does
Thanks. I've ordered a CD for the 2246.
That makes sense. I'll dig out one of my old scopes to look at it, just
using a DVM may be giving me a false picture.
I may just replace the FET anyway and see what happens.
Sounds like a good investment!
Tnx, Alf
Alfred Green
Techie said:
I found my Service manual and its for a 2445A
It looks like there are some similarities, but not quite enough. I
appreciate your efforts in sending me the diagram; I'll keep it for future
reference.
Tnx, Alf
Jim Yanik
future reference.
Tnx, Alf
The 2245 and the 2445 and A versions are nothing alike.
Two entirely different families. Different architectures.
Now,2445 and 2465 (and A,B versions)are very similar;and 2245 and 2246,2247
are very similar.
