Tektronix 2430 digital scope errors
Andy Cuffe
I'm trying to repair this Tek 2430 digital oscilloscope which is
failing the self test. It lists the following errors:
7000 CCD
7100 CENTER
7200 GAIN
8000 PA
8100 OFFSET
8200 POS-GAIN
8300 BALANCE
8400 GAIN
8500 INV-GAIN
8600 VAR-MAX
8700 ATTENUATOR*
9000 TRIGS
9100 OFFSET
9200 GAIN
After exiting the self test menu, it displays a random looking
sinusoidal waveform on ch 1 and 2. The centering controls work, but
the voltage and sweep time have little effect on the display. I can't
see any obvious problems. What kind of problems have people seen with
this scope? Any idea what could be causing all these errors?
Andy Cuffe
[email protected]
TekMan
7000 CCD
7100 CENTER
7200 GAIN
8000 PA
8100 OFFSET
8200 POS-GAIN
8300 BALANCE
8400 GAIN
8500 INV-GAIN
8600 VAR-MAX
8700 ATTENUATOR*
9000 TRIGS
9100 OFFSET
9200 GAIN
Andy Cuffe
[email protected]
Andy,
you'll have to change the CCD first. and pls. check the power supply for ripple.
If both is okay, rerun the calibration menu. Most errors will be cured then.
Runnig the cal menu without a known good CCD won't help.
the CCD s are hard to get,
so good luck.
hth,
Andreas
Andy Cuffe
Andy,
so good luck.
hth,
Andreas
Does anyone have a service manual in electronic form they would be
willing to share? This is a complex scope and I would like to know
what I'm doing before I try anything.
Andy Cuffe
[email protected]
Amiga_for_fun
I do also have almoust the same errors then booting
up my 2430a and I can´t solve it by re selfcalibrate.
Sometimes it does not boot at all, it only gives me a orange screen and
the two leds, "raedy" and "arm" are set.
Icom
Jul 10, 2009
3
I'm a new user.
I've a 2430A oscilloscope that show an identical condition of error of Andy Cuffe. :(
Please Andy, how did you resolve the errors?
If there are other people that can help me, is great! :)
Thank you.Icom.
