Tektronix 2430 repair
Status
Not open for further replies.
bigone5500
Apr 9, 2014
712
I finally got the scope from work that I was trying to get some time ago. As you can see, there is a blob on the screen and nothing changes it, knobs or buttons. Does anyone know what could be going on? Is it a futile endeavor?
Heliman
Feb 4, 2016
65
If your time base wont expand the "blob" I would get a service manual and trouble shoot the sweep section and make sure all voltages are within specs
73's de Edd
Aug 21, 2015
3,730
Sir bigone5500
. . . . . .aka Jared . . . . .
Firstly I wonder if you have tried adjusting the green blob control to its optimum ?.
Also, next, see if the bottom left intensity control causes it to get worse at its maximum CW position,
or getting better at its adjustment range towards the left. . . .CCW. ?
Now in retaining YOUR display but marrying on my controls on the right so that the panel can be read .
I am worrying about the compressed hoz display aspect. . . . .being basically due, just by controls / settings MISADJUSTMENTS.
In the central HOZ adjustments cluster, confirm that the unit is in its A time base mode and not in the B mode. by pressing A mode and the seeing if the RED circled hoz position will adjust the blob right to left positioning. If so. . .
Change the RED marked VAR time base control to the left to get a slower time base and an inherently increased brightness at the slower speed . . . . but shop well short of getting a slowly sweeping dot speed.
We are looking to getting a FULL line of sweep width.
Even with only your learners permit . . . . we are now authorizing the use of a small standard blade screwdriver to now adjust the recessed and slotted FOCUS control located within the bottom frontal left corner.
Any change ? if not, try astig and finally trace rotation, but NOT expecting anything from the last duo, due to the units present resolution capabilities.
If the FOCUS was dead of responding to any of those adjustments . . .ONWARD . . . to pull the dust covers and access to the central area of he units innards.
The area of interest will be marked by the easily noticeable and most honnable . . . MURATA RED AND BLACK cased high voltage multiplier and the SMPS transformer just across from it.
Our transistor of interest is marked up on both the schema and the picture.
We are interested in finding if the focus control adjustment produces any voltage swing at reg points RED A and RED B.
Standing by to see how you are making it . . . . . . . .
FRONTAL ADJUSTMENTS AND CONTROLS REFERENCING
SUSPECTED PROBLEM AREA SPECIFICAS
73s de Edd
bigone5500
Apr 9, 2014
712
Thanks for the replies. I will be checking voltages and will report back with my findings.
bigone5500
Apr 9, 2014
712
Forgot to mention that I got the type 500A scope mobile to boot!
No...the scope mobile doesn't actually boot up...
bigone5500
Apr 9, 2014
712
Sir bigone5500
73s de Edd
Sir, could you tell me how to remove the black retainers that secure the pcb? They look like ones that I have dealt with in the past but will not come out. I give them a quarter turn but they sound like they are about to snap.
I figured it out. The 'heads' do not come out. The board simply lifts up.
73's de Edd
Aug 21, 2015
3,730
That used to be common practice back in discrete component days .
Even the use of a dishwasher .
Myself, I would use hot water, a hog bristle brush and either Fantastic or 409 ,more scrubbing, a rinse and use a final " sling drying ". Then a spaced away heat gun for the final traces of wetness.
NOWADAYS . . . .I use a leafblower.
Those dusty and dirty boards would then come out SPARKLING CLEAN.
Your unit has some hybrid and VERY pricey hybrid components on it .
73's de Edd
bigone5500
Apr 9, 2014
712
Well...as I do not have any of the equipment required for calibration and tests aside from the usual multimeter, I will have to abandon this scope. I was hoping to get it to work somehow and without much effort but not having the correct testing equipment makes it impossible.
I have a Rigol DS2072A which works very well and has all the fantsy upgrades so it's all I need.
Thanks for the help anyway.
Vinman21
Jan 15, 2023
Hello, has anyone found a solution to this failure? I have a scope with the same issue.
danadak
Feb 19, 2021
1,103
This sounds like a firmware issue where no controls are being responded to.
I would raise slightly then push back into socket any socketed IC for starters.
Look for loose PCB screws, especially ones that are path for grounding.
Clean connectors and flat ribbon cables. Be careful and extremely gentle with
PCB based flat ribbon connectors, they are very fragile and the plastic ages
and easily broken.
Follow equipment cleaning procedures in manual, decades of dust and aerosols,
like cooking oils, bad breath......Pay particular attention when cleaning HV sections
not to lave any residual cleaning chems or films.
Look at power supplies to make sure they are all in spec. Look for electrolytic
caps to see if they are bulging on top for replacement. Look for tants that have
leaked. Hot spot on board that dont look right.....Lots of videos on YouTube
on repair and hints and techniques.
Tek has ap notes on cleaning, make sure you get the one(s) for the period
instrument you have.
Use the Tek Museum resources for Tek Notes and the like. Contact them for advice.
Here as well - https://groups.io/g/Tektronix
Regards, Dana.
Vinman21
Jan 15, 2023
Opened it up today and found all low voltage supply voltages were low or missing, starting with recapping the LV supply as the unit is 33 years old, I'll update once I get the caps and replace them.
Mr Magoo
Feb 5, 2026
I appreciate that this is well late in the day, however I resolved this problem by replacing the four 2.7µF caps on the A11 board. C181 C182 C282 C284.
That said, it is essential that the LV PSU board is working properly.
Status
