temperature sensor with digital output
circuity
Feb 23, 2006
15
this is my circuit. I have several questions:
a) i dont have any output at the VOUT (2) of LM35DT. Why?
b) how can i replace the LED display with 7-segment display. What do i need to add?
c) transformer with what current rating should i use?
d) what brigde rectifier should i use?. Please tell the model number.
Thanx
audioguru2
Apr 6, 2004
12,022
It needs an amplifier to boost its output of only 10mV/degree C.
Program the microcontroller for it.
The circuit's current is very low. Calculate or measure it.
The LM317 regulator is missing a resistor, therefore its output voltage is only 1.25V.
circuity
Feb 23, 2006
15
can i use a uA741 to amplify the output of LM35DT..?
what microcontroller should i use...?
im a newbie in electronic circuits...... ???
thanx audioguru for ur fast reply
Tony_Stoynov
Dec 20, 2005
197
Yes you can, but must think about input offset voltage, you must make the input compensation. I can suggest to use more precision OPAMP, something like MCP606/7/8/9 from Microchip or OP-41, OP-07 etc.
