Test Fixture patch bay Diodes?
Davewalker5
Sep 20, 2014
125
On test fixtures , they have a patch bays that has multiple jacks on the front panel
What does these diodes do? the diodes are in series
If you plug the wrong jacks together, how does these diodes protect the text fixture?
If a tech injected a Positive voltage into a jack , how would a series diode protect the text fixture?
If a tech injected a Negative voltage into a jack, how would a series diode protect the test fixture?
14,312
You need to supply more information:
- What kind of patch bay is this?
- What are the test fixtures used for?
- Where does the DC voltage (left side of your pictures) come from?
- Where does the right side (patch bay jack) go to?
- Why would someone "inject" a voltage on the patch bay jack's side? The power seems to be supplied from the left (DC voltage).
Davewalker5
Sep 20, 2014
125
Harald kapp
here is the pictures of the patch bays on the test fixture
Also I don't know the names of the size of the red and yellow patch bay cables and plugs are called, do you guys know?
But each jack on the patch bay has a series diode soldered to the jack to a wire that does to the test fixture
The Series diode is to protect the test fixture, but how so?
If the patch cable is in the wrong test fixture jack to another jack it will damage the test fixture, the series diode protects the test fixture from wrong connections
Some Test fixture tests have +15 vdc, -15vdc, other AC and DC voltages
14,312
We cannot answer your questions without knowing how the test fixture works.
