thanks + how to detect a persistent signal anomaly
gst
(i'm posting here because i could adopt both an hardware or software
solution (having a fixed point dsp available); _if you think i'm
off-topic_ and that the solution lies on the software side, i can
re-post the question on comp.dsp, virtually "closing" the thread
here...)
hello
i would like to thank you for the answers to this thread
http://groups.google.com/group/sci....51e91dfcff1/399783a22eb72bb4#399783a22eb72bb4
which have been *extremely* useful and effective both in understanding
my problem better and as a solution; after some exploration we chose a
specific gaussian filter which - for the kind of application i'm
working on - behaves "spectacularly well" ;-)
now to _my current problem_ (i'm looking for *any generic hint about
the subject*, then i will google about what you suggest):
i would like to recognize an incoming persistent anomaly of the signal
(for example "sudden offset increase": what should be "zero" suddenly
becomes +2 because of sudden voltage skew and stays like that for a
reasonably long amount of time (not a "spike"), or sudden "white noise"
because a wire gets loose, or....)
i would like to do that "as fast as possible" (where "fast" means "with
the shortest latency/delay possible with respect to the appearance of
the anomaly on the signal")
does exist a standard way of dealing with anomalies? a "toolset of
procedures" i can study to understand what i can do?
since i think that the kind of problems i can face could be related to
the sensor technologies: i'm using cheap micromachined capacitive
accelerometers. the system can tolerate the specific sensor noise but i
don't know how they can _malfunction_.
thank you again, guys!
gst
I
Ian Stirling
What's your signal?
Google "maximal likelyhood detection".
You need to model your signal, perhaps using more than one sensor, and
model.
Now, generate a signal with differences between your model (where
'difference' is dependant on your measuring) and your signal.
For example, with a diesel engine, if your input is a vibration sensor
next to the crankshaft, and an additional sensor is a voltage divisor on
an injector, with a crank position sensor as a third, you might have
four seperate models running.
One which uses all three sensors, and one each with a sensor missing.
You flag an error on significant divergance.
gst
Ian said:
What's your signal?
model.
right now i'm googling for MLE/MLD thanks
the signal:
- i have the 1 accelerometer for each axis (thus no redundancy right
now, but i could ask for more...)
- basically i have to quickly detect a mechanical shock, and
distinguish it from an anomaly.
- the shock detection must be very very quick, thus i think i cannot
see enough signal to find peculiar frequencies if they exist (and being
the shock a sort of "prolonged impulse" i don't think they are there, i
cannot spot them using fft analysis or "eyeball detection" ;-) ). right
now i distinguish it from normal behaviour using only time/amplitude
information.
- the shock is itself something very different from the
usual/statistical behaviour of the system (where everything is usually
"quiet")
- i think this could be a problem to distinguish it from a quick
voltage increase caused by an hardware problem.....
