That global warming thingy
Eeyore
Don said:
This is not most of the ice in either the arctic or the antarctic. Most
of the ice in each location is icecap on land
You think there's land at the North Pole ? Do grow up ! I never realised how
idiotic most ppl were !
The Arctic Ice that's currently melting is all *sea ice* !
As for Antarctica it's so damn bloody cold that the ice on the land is in no danger
of melting probably ever..
Graham
MassiveProng
Somehow I think Mars has a problem of insufficient gravity to hold onto
a good atmosphere.
Huh? You are thinking of the moon. Mars HAS an atmosphere already.
Mostly CO2. Where do you think the 200MPH winds come from? Then,
there's those cool purple sunsets!
Doh!
Eeyore
Don said:
Most deep ocean is more like 5 km deep.
So when I said in my other post 2.4 meter sea level rise from thermal
expansion being on the alarmist side, take that down to 1 meter to correct
from 12 km to 5 km average ocean depth.
*AVERAGE 5km* ? Are you barking mad ?
" The area of the World Ocean is 361 million square kilometers (139 million sq mi),
its volume is over 1,340 million cubic kilometers (319 million cu mi), and its
average depth is 3,711 meters "
http://en.wikipedia.org/wiki/Ocean
Have you never heard on things such as the Continental Shelf ?
http://en.wikipedia.org/wiki/Continental_shelf
And to think I gave up geography because I didn't do that well at it !
Graham
Eeyore
MassiveProng said:
Still massive percentages of them are land borne. I know a large
apron floats that is not breaking up, but that wasn't my point.
You're referring to the Ice Shelf there AIUI.
Graham
Eeyore
MassiveProng said:
Eeyore Gave us:
Didn't we just have this ice/waterline discussion a couple months
back?
I do believe you are right.
I am stunned at the poor level of education being illustrated.
Graham
Jeff L
Eeyore said:
Where ? I thought mainly 3 km for deep ocean.
My mistake from memory - that is the depth of some of the deeper ridges /
trenches in the ocean.
Where did you get your 1% from ?
It was just a quick calc to show how an seemingly insignificant number like
1% can make a huge difference.
To be a little more precise on a 1st order basis, and assuming everything
warms up the same amount on average:
The average depth of the ocean is 4,000m, ( from:
http://www.mbgnet.net/salt/oceans/data.htm , which seems to agree with the
other data I just looked up)
The thermal coefficient of expansion of water is about 0.00021 per deg C, at
20 deg C. Assuming this does not change significantly at most ocean temps,
then, according to http://en.wikipedia.org/wiki/Global_warming , the
predicted global temperature increase is 1.1 to 6.4 deg C from 1990 to 2100.
So, best case is: 4,000 m * 0.00021 * 1.1 = 0.924 m
Worst case is: 4,000 m * 0.00021 * 6.4 = 5.376 m (17.64')
Not as significant as I expected, but still enough alone to take out a good
chunk of coastal land, including many cities.
Some intersting info on the topic:
Water volume in oceans: 1,320,000,000 km3, and world 1,360,000,000 km3
Interestingly, the ice caps and glaciers only account for 1.8% of this
(25,000,000 km3) From: <http://en.wikipedia.org/wiki/Water_(molecule)>
Some more interesting info:
http://en.wikipedia.org/wiki/Sea_level_rise The sea has risen 130 m from
the last ice age @18,000 years ago. Also interesting is the stated info from
the 2001 IPCC report has now changed the expected ocean rise to be a very
small 9 to 88 cm in 2100.
And it's not all 12km deep btw. In fact I know of nowhere that deep. A heck of a
lot of it is shallow.
Plus it takes apparently ~ 10,000 years to make
significant changes in overall ocean temperatures.
Please cite that reference.
http://en.wikipedia.org/wiki/Global_warming - states "Relative to the
period 1860-1900, global temperatures on both land and sea have increased by
0.75 °C (1.4 °F),rise" Considering a 1 or 2 degree rise makes major changes
in weather patterns alone, I'd say that's very significant.
Also worth considering in that previous measurement, is the enormous growth
of energy consumption as the worlds populations grew and individuals
consumed more and more energy since the industrial revolution started to
take off in the late 1800's. In other words, the rate of temperature
increase should be rapidly accelerating. Hopefully there is a negative
feedback loop to stabilize the system, like water vapor, which is a green
house gas, but hopefully it will reflect enough thermal energy back into
space to create the negative feedback that is needed.
Maybe you ought to study science before posting ?
Perhaps it is you who ought to study science before posting.
Eeyore
Jeff said:
Really ?
It seems that I was the one correcting you.
Graham
Eeyore
Thank you.
Which goes to show that a quick mistake like that can produce utter garbage
results ! That is indeed the mark of AGW activists.
3.7 km acc to Wikipedia actually.
A damn sight closer to my off-the-cuff estimate of 3km than yours of 12km !
Tell me something. Did you stop to consider how long it would take the oceans to
rise in temperature by 6 degrees?
Maybe you'd like to consider that ? How many Joules would it take for example ?
< snip rest of blather >.
Do please study some stuff before spouting a load of crap again will you ?
Graham
Don Klipstein
Some extremely thin one comprised mostly of CO2. They get a few dust
storms.
Put much oxygen there with its lower molecular weight especially in the
case of a thermosphere, and see how long it stays. Maybe millennia, maybe
a bit more, ???
Don Klipstein
No, I am not considering nonexistent land in the Arctic Ocean, but I am
surely considering Greenland!
in no danger of melting probably ever..
Record high at the South Pole so far is -13.6 C, but most other icecap
area has gotten warmer than that. Also, I expect icecap melting to be
from the edges where it is warmer. As the icecaps get eaten away at their
edges, solar heating in those areas will increase as land that was covered
by ice gets exposed.
Probably no problem until/unless we exceed highest global warmth already
achieved during interglacial periods of the past few 100,000 years, but
there are projections putting this within a century. Of course, the
icecaps would take longer than that to melt.
Don Klipstein
I was correcting a calculation I improved upon without considering as
erroneous a depth of 12 km. Most ocean outside the continental shelves is
about 5 km deep, so I used 5 km as a correction over 12 km.
Take a bit off for continental shelves... I do not consider 5 vs 3.711
km ocean depth "barking mad" when proposing that a few degrees rise of
temperature of this is only good for raising sea level by a meter.
Certainly not as "barking mad" as not considering Greenland's icecap to
be arctic ice.
Don Klipstein
It does. Most of the ocean mass is at temperature where the coefficient
is a lot closer to zero. Some is at temperature where the coefficient is
negative.
Michael
Eeyore said:
I liked the way he said he realised the 'environmental movement' had lost its
way when at a Greenpeace meeting they were discussing *banning sulphur* ! As he
put it "to discuss banning a element in the oeriodic table!".
Graham
chlorine you mean.
Mick C
Jeff L
Eeyore said:
So what are the numbers ?
They are easy to find.
Salt water at around 0 deg C with typical salinity: 1.029 g per ml
Fresh water at 0 deg C: 0.9999 g per ml
So salt water is approx 3% more dense, which means it will push the ice
about 3% further out of the water then fresh water would.This means the
water level would increase slightly, while the average density would
decrease slightly upon melting.
Ice that's on land is entirely another matter. It's not being warmed by the
oceans so it's not going to melt any time soon.
I thought you said it takes 10,000 years for a significant change in
temperature of the oceans. To me, a change in ocean temperature enough to
melt that ice is pretty significant.
Temperatures in Antarctica are up to MINUS 90 DEGREES CELSIUS ! Some say the Ice
there is actually growing due to more water vapour in the atmosphere.
Interesting. References on the accumulating ice?
Jeff L
Eeyore said:
Really ?
Graham
Fair enough, however, where did this come from?
Plus it takes apparently ~ 10,000 years to make significant changes in
- Acoustical measurement practices have shown average ocean temperatures in
many areas to have risen ~0.5 deg C from recent periods such as mid 1990's
to year 2000 (generally a 5 year span). Here is some info on the arctic
ocean, for example: http://www.acoustics.org/press/144th/Mikhalevsky.htm
- The average planet temperature has risen 0.75 deg C over about the last
century: http://en.wikipedia.org/wiki/Global_warming - states "Relative to
the period 1860-1900, global temperatures on both land and sea have
increased by 0.75 °C (1.4 °F),rise" Considering the industrial revolution
has sustained enormous growth from that period, and the world population has
also grown enormously, those numbers are likely accelerating at staggering
rates.
So this shows that significant temperature changes can occur on the order of
several decades to a maybe a few centuries.
Eeyore
It's called the *Greenland Ice Cap* ! It's not yet melting.
What about the bits @ -90C ?
Graham
Eeyore
And my 3km guess is closer still to the actual figure.
Ho long would it take the oceans to rise in temp by 2 degrees ?
Graham
Eeyore
negative.
In other words it's not really an issue we need to worry about. At least not for
a millenium or two.
Graham
Eeyore
Michael said:
chlorine you mean.
I was sure he said sulphur actually. Makes as much sense either way. Life probably
wouldn't exist without either.
Graham
