John said:
On Jul 31, 7:21 am, Jim Thompson <To-Email-Use-The-Envelope-I...@My-
Web-Site.com> wrote:
[snip]
I don't ever recall saying "more-efficient-at-higher-speed".
But I guess it WOULD depend on your definition. The engine is
optimized right around 3000RPM (85MPH), but external drag is higher.
If you shift to a lower gear, 3000 RPM is at a lower speed. If there
isn't an issue that is well modeled by a fuel leak, the milage would
improve.
Ever consider that transmissions aren't equally efficient in all
gears and perhaps the over-drive locked-up may be a tad more
efficient than the lower gears? There is also work done just
spinning the engine. Me thinks you're wrong.
Don't both Honda and Toyota have models with CVT (continuously
variable transmission) which keeps engine RPM's in a narrow/optimum
range?
...Jim Thompson
CVTs are still the holy grail of car design, but none of them seem to
work at serious horespowers. They are the equivalent of a switching
regulator.
It is, in a way, done with switching regulators. A small engine runs at
a fairly constant rpm and drives a generator. That goes into a switcher
which in turn feeds one or more motors that drive the car. The balance
goes into a battery and the engine stops when that's topped off. Pretty
much the hybrid concept.
AFAIR the closest recent approach to a roadworthy CVT was from Ford but
I haven't heard about it in a long time. The first mainstream CVT in a
car was actually brought to market in the 50's. My mom had a "DAF 44", a
Dutch car. A picture is worth a thousand words, so this is a picture of
the CVT in that type of car:
http://upload.wikimedia.org/wikipedia/commons/3/3d/DAF_Hinterachsantrieb.jpg
I became intimitely familiar with this CVT because as a kid I had the
"pleasure" to take the whole heavy CVT out. Only to find out that all
that was broken was a small governor weight in one of the "bells". Could
have fixed in with the CVT in the car. Arrrgh.
This car only had a "forward-reverse" switch and no clutch, plus another
smaller switch to increase rpm while muffling the throttle. The only
passenger car I ever saw that had a kind of jake brake. The car could go
80mph in reverse and in the Netherlands they actually had "reverse
races". Naturally, DAF was the only brand of car that could play. I
tried it once but quickly gave up because you can easily roll the car
that way.
Quite innovative but because of the belt friction the fuel consumption
was rather dismal, couldn't yield much better than 25-30mpg and that was
not good enough for European standards. IIRC the company sold out to
Volvo and then this concept petered out.
