The Theremin Stretch
SparkyCal
Mar 11, 2020
863
Hi Bertus- I am following the breadboarded version on the video, as I already built it. It calls for a 4-50pf I believe.
bertus
3,882
I see that the breadboarded version uses the 4 to 50 pF.
You can still try the 8 to 40 pF capacitor.
When it has a to low value, you can put a 15 pF fixed capacitor in parallel.
Here I found a video that explains the use of a "real" (commercial) theremin:
Bertus
SparkyCal
Mar 11, 2020
863
Hi...I bought the J110's and popped them in, as well as the 8-40pF capacitor. I am still not getting any sound. However, the new capacitor has three pins and i am not sure I hooked it up correctly. I hooked one of the pins to one side of the 1mH inductor , and the other to ground. I'm not sure what the third pin is for, or whether I hooked up the other two correctly.
bertus
3,882
The two side pins are connected together, the other pin is the other side of the capacitor:
Bertus
SparkyCal
Mar 11, 2020
863
Bertus
Very cool. Makes me want to buy one
SparkyCal
Mar 11, 2020
863
Funny- still no sound.
R 12 and R 42 continue to show zero volts. Is there anyway of breaking this down and testing voltages at certain junctures to determine where the breakdown is?
bertus
3,882
Did you use the correct pin-out?
Bertus
SparkyCal
Mar 11, 2020
863
I did because the previous jfet I used had a different pin mapping which coincides with the j110s mapping. So I basically just had to swap out the jfets with the new j110s because the components had already been adjusted.
Bertus
Audioguru
Sep 24, 2016
3,656
In the video, I liked the bubbles playing sounds and the pedal making chords.
The woman with the severe English accent was talking in a room that had severe echoes. She has a speech problem that causes every sentence to fade away like she was running out of breathing air.
SparkyCal
Mar 11, 2020
863
Hey guys...as mentioned, I will be leaving soon and back Sept 7th. I don';t think i will have time to trouble shoot the theremin. between now and then, but plan to get back to it, when i return. Bertus- I also plan to read about theremin design, when i am away. I figure, if I can better understand how they are built, it can't hurt with the trouble shooting.,
