Thermal fuse on printed circuit board
Willie9240
Dec 16, 2022
4
Hey I have this thermal cutoff fuse and I want to find a replacement.
But if I can find a data sheet or spec sheet with your help that’s all I need to find a compatible fuse to use.
The fuse has this printed:
A-YX01
E478338
ru 94V-0
HRS2057-C
16.05.08
Thanks in advance
Willie9240
Dec 16, 2022
4
Yeah these are both sides
73's de Edd
Aug 21, 2015
3,730
To me . . . . . that just looks like a blown fusible link that was etched on the copper foil and is dependent / and / needing to be replicated of the same dimensions and using the same oz weight of foil.
Definition of detail, precludes my making out the associated background clutter, but is being automotive related ?
kellys_eye
Jun 25, 2010
6,512
As per Edd above - you could fit a standard fuse of the appropriate rating and, potentially, a proper holder for the fuse too (allows easy replacement). Tell us more about its purpose, the equipment etc. Looks to be around 20A or 25A to me.
Willie9240
Dec 16, 2022
4
DEWALT DXAEJ14CA Booster Pack/Jump Starter, With Auto-Stop Digital Air Compressor, 1400 Peak Amp, 12V​
It’s for this but I can’t find any details on it or data sheet for it, but both of you are right and yes as Kelly said above im trying to find a compatible fuse with the holder so if it blows or I need to replace it then it’s a lot easier.
kellys_eye
Jun 25, 2010
6,512
Kinda think there's some exaggeration in the specs..... either way, the 'fuse' you're referring to certainly isn't rated at anything over 30A as the WIRE it's connected to seems to be 14awg (?) therefore 30A is the 'recommended limit.
The only reasonable fuse holder would be what's called a 'blade fuse holder' - standard stuff for vehicle use and readily available, as are the fuses. Start with a 25A fuse....
Willie9240
Dec 16, 2022
4
That’s exactly what I wanted to use just wasn’t sure if I could, the other thing I wasn’t to sure about is if I should use a standard one or a small fuse holder.
SugarandWasabi
Jan 20, 2024
Hi There, I have the same issue, trying to find replacement of this fuse, did you end up fixing yours with a blade fuse?
14,486
This thread is over 2 years old, the OP may no longer be around.
The solution given in post #7 should give you the desired result
