Thermal resistance of small SMDs versus Copper Pours
  • Thread starter Klaus Kragelund
  • Start date
K
Klaus Kragelund
Hi
I am looking into how much I can dissipate in a 0805 or 1206 resistor.
A discussion on SED about the topic a while back:
https://groups.google.com/d/topic/sci.electronics.design/3GPk1GPreks/discussion
In the discussion:
Qoute
There is a
National datasheet somewhere that has a bunch of examples of
various-shaped copper pours and their thetas. Maybe someone here
remembers which it is.
Unqoute
So what I am trying to find is that Natinal datasheet or app note. Google was not my frind after extensive search :-(
Anyone got that app note in their archive?
Cheers
Klaus
Lasse Langwadt Christensen
Den onsdag den 4. december 2013 12.02.50 UTC+1 skrev Klaus Kragelund:
Hi
In the discussion:
Qoute
There is a
Unqoute
Cheers
Klaus
maybe this is the one?
http://www.ti.com/lit/ds/symlink/lm1117-n.pdf
-Lasse
K
Klaus Kragelund
Yes, it certainly has very good information on the subject, thanks :)
It's kind of strange that apparently no information (including thermography plots) of dumping power into 0805 and 1206 resistors exists.
Cheers
Klaus
Joerg
Klaus said:
Hi
In the discussion:
Qoute
There is a
Unqoute
This is pretty good even though the resolution of figure 7 is poor:
http://catalog.osram-os.com/media/_en/Graphics/00017064_0.pdf
If you have to push performance within a given real estate consider
side-contact resistors for increased heat transfer:
http://www.welwyn-tt.com/pdf/application_notes/LRCvsMSR_AN_A.pdf
K
Klaus Kragelund
We've done a bunch of work on this, keeping resistors cool with copper pours.
You can push an 0603 to at least half a watt if you keep the end caps cool. The
central hot-spot temperature of 1206 through 0603 resistors are about the same
at equal dissipation if they are on big pours.
0805 on small single-side pours:
https://dl.dropboxusercontent.com/u/53724080/Thermal/140K_per_Watt.jpg
1206 RTD:
https://dl.dropboxusercontent.com/u/53724080/Thermal/RTD_in_air.JPG
https://dl.dropboxusercontent.com/u/53724080/Thermal/RTD_on_board.JPG
https://dl.dropboxusercontent.com/u/53724080/Thermal/RTD_lotsa_copper.JPG
(note the delta-v cursor values on the first and last. I flubbed the middle
one.)
That's a nice trick, using the RTD for both the power dissipation and measurement, will reveal the correct thermal resistance delay
Cheers
Klaus
legg
Hi
In the discussion:
Qoute
There is a
Unqoute
Cheers
Klaus
You may be looking for Nat Semi AN1025 for SOT23.
AN1028 covers patterns for SOT-223
There was one for SOIC parts, but I seem to have mislocated it in
electronic format.
Strangely enough, there are app notes with the same numbers from
Fairchild.
RL
legg
Hi
In the discussion:
Qoute
There is a
Unqoute
Cheers
Klaus
Also - check out IR AN994.
RL
legg
Hi
In the discussion:
Qoute
There is a
Unqoute
Cheers
Klaus
AN1029 is SO8
RL
legg
Hi
In the discussion:
Qoute
There is a
Unqoute
Cheers
Klaus
For a good time, google "Package and Thermal Information" to see some
thermal images for different package patterns from Infineon.....
RL
