John Devereux
- Jan 1, 1970
- 0
Bart! said:[...]
We do actually have an aluminium block too, but it is mainly coupled
to the groundplane rather than the LED itself (because of
manufacturing tolerances). Fixed pitch font:
. | LED
. V
. _
. [XXXXXXX]| |[XXXXXXX] <--- 5mm Aluminium plate
.PCB =========================================
There are some vertical screws clamping the whole thing up to the
metal block of the product.
The critical thing is to cool the baseplate of the LED, so the thermal
interface to the groundplane is what I was concerned about.
I am liking Spheros idea of mounting it from behind the board more and
more:
. [XXXXXXX] _ [XXXXXXX] <--- 5mm Aluminium plate
.PCB ===================| |=====================
We could put some bolt heads either side of the led base to clamp
everything up really solidly without needing any adhesive. We would
need to carefully trim the anode lead and bend it around to a solder
pad. The cathode could just be be snipped off. A bit labour intensive,
but much better than gluing.
A nice, large annular ring plated thru hole IS a very nice way to mount
it. If that is your choice, you should also surround that hole with some
cladding
Not sure what you mean by "cladding"?
and add some smaller plated thru holes as they increase the thermal
mass of the PCB and make it conduct heat better Then you could place
little heat radiators 'posts' into the other holes on the underside
of the board and air currents can carry a lot of the heat away from
the PCB.
Could do - we have a lot of vias already, and I think those combined
with the Aluminium plate should be more than sufficient!
