Thermostat setting on Frigidaier refrigerator/freezer combo
W
Wolfi
Well, I'm aware, that this isn't quite an "electronics" question, but I'm
hoping to get an answer here anyway.
On an older (guessing some late 60s, early/mid 70s model), light green, big
US Frigidaire refrigerator with icebox in the top area, I'm wondering what
the thermostat settings (in the refrigerator section) mean:
there a three positions labelled Off--A-B-C and if you turn further, three
more, labelled 1-2-3.
So now what are the A-B-C doing and what are the 1-2-3 for?
H
hr(bob) [email protected]
Can't you find a model number somewhere???
W
Wolfi
Am 21.08.07 21.22 schrieb hr(bob) [email protected]:
No, so far I didn't have any luck. All the common and obvious places I know
about don't carry a label. I was curious myself about the power rating, but
w/o the label ... (I'm not in the mood to go through hoops for it)
I just assumed, that this type of thermostat, with alphanumeric positions
was/is something quite common and in use for a longer period of time, so
that it it is something like "common knowledge" for mid-aged Americans.
W
Wolfi
BTW, there is one more characteristic that I forgot to mention: the power
cord still is only a 2-wire and 2-prong type. No protective ground pin yet.
jakdedert
I'm hoping to get an answer here anyway.
big US Frigidaire refrigerator with icebox in the top area, I'm
wondering what the thermostat settings (in the refrigerator section) mean:
three more, labelled 1-2-3.
Colder and warmer...degrees thereof. What did you expect?
Okay...if you look closer, you might also see a note explaining that
lower/higher numbers/letters mean colder/warmer. That's been the case
in every fridge I've ever had. Otherwise, you might have to do some
research. Likely the answer is google-able.
Try it.
jak
W
Wolfi
Am 21.08.07 23.53 schrieb jakdedert:
Sure, the direction of higher numbers mean colder, as is also indicated by
an arrow on the side BUT to me it doesn't make any sense to start with
A-B-C and then go on with 1-2-3, rather then go from 1-....-6 in the first
place. That is illogical.
I was more thinking that the 2 groups might have something to do with
different emphasis on the freezer, respectively the fridge section
temperature settings, but I simply don't know and also wouldn't know, which
one would work which way.
That's why I asked here.
Try it.
I did, but came up empty.
Sam Goldwasser
indicated by an arrow on the side BUT to me it doesn't make any sense
to start with A-B-C and then go on with 1-2-3, rather then go from
1-....-6 in the first place. That is illogical.
which one would work which way.
You could try the experiment. :)
There are a number of large appliance Web sites with a place to ask
questions. You may have more luck there. Some of these guys consider
something as electronically simple as a fridge to be beneath them.
Just kidding. :)
Links from: http://www.repairfaq.org/sam/sambook.htm
under "Appliance Sites" (about 2/3rds of the way down the page)
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
W
Wolfi
Am 21.08.07 20.33 schrieb Wolfi:
I have to correct myself.
It's actually: Off--C-B-A-1-2-3 and not Off--A-B-C-...
H
I am old enuf to go back that far and even further, and I must say I
have never seen a refrigerator with anything except total numbers or
total letters, never a combo.
Bob Hofmann
Have to amend my earlier post, I have seen DEF (for Defrost) and then
a numerical sequence.
Bob Hofmann
W
Wolfi
Am 22.08.07 10.50 schrieb hr(bob) [email protected]:
Yep, that also fits within my experience and that's why this one is
puzzling me so much.
The more modern and convenient ones have a DEF setting. For all the other
ones, one just has to turn the thermostat off for some time, open the doors
and safe keep cold, whatever was inside.
