Thick or Thin Film Resistors
Rajinder
Jan 30, 2016
568
I wanted to ask if I have a thick film resistor with the following specifications:
Case size 0603
Tolerance +/-1%
Voltage 50V
Value 10K
Temp coefficient 100PPM/C
Application is for ultrasonic level measurement
Can I replace this with a thin film resistor with a like to like spec? Or are there other parameters to consider.
Best regards,
Raj
Arouse1973
Adam
Dec 18, 2013
5,178
Yes you can as long as the product is not used in a high humidity environment as thin films have a greater tendency to absorb moisture. They are a superior resistor over thick film in many ways, but are normally more expensive.
Adam
