Thoughts on LED Replacement of 8ft Tubes
Fish4Fun
So long, and Thanks for all the Fish!
Aug 27, 2013
481
I have been working on an economical way to replace ~40 8ft F-Tube lighting fixtures for the past decade or so...with each advancement in LEDs I re-figure, recalculate and procrastinate.....The most recent cycle involves the 10W chips nominally 12V / 900mA with peak efficiency ~ 10.0V ~ 600mA.....Real World testing suggests 12 - 18 chips provide equal or greater lighting effects than a single 8ft 2-tube fixture (LEDs @ 72W to 108W when driven @ 600mA......compared to the base line ~160W of the F-Tubes).....So the problem is now reduced to driving 12 to 18 "10W" (actual power ~ 6W each) LED chips * ~40 fixtures.....Obviously this is a non-trivial consideration....A single 650mA 190Vmax driver is available for ~$60.....another possible solution is a 36V 600mA driver for ~$3.50ea....obviously this would require 4 to 6 of the drivers netting $14 to $21 per fixture, while the installation would be a bit more involved this route offers the potential of reduced long-term maintenance by decreasing the cost per failed driver.......There are a myriad of other potential solutions using readily available drivers.....But.....
At the end of the day,it would be ideal ito have ~160V to ~180V regulated @ 600mA.....
And this has led me down a dark and potentially dangerous path....As luck would have it rectified line voltage is nominally ~170V....assuming 17 LED chips in series @ a nominal forward voltage of 10.0V each @ a "natural forward current" of 550mA it is very tempting to forgo any driver at all.....I know, it is an insane idea! But is it really? The rated voltage of each LED is nominally 12V so a circuit to "clamp" the voltage below 204V would be important to protect the LEDs from surges.....beyond that, actual testing of the LEDs demonstrates they operate continuously @ 11.0V @ ~900mA (9.9W) if properly cooled....this would imply that the series could withstand ~187V indefinitely....Further testing indicates that @ 153V the LEDs operate @ ~310mA (2.82W) at roughly half the brightness they have @ the nominal 170.0V, so the series would natively still be "functional" @ +/-10% ( 170Vdc - 17Vdc = 153V 170Vdc + 17Vdc = 187Vdc) without any dire implications....
Because the LEDs are intentionally being driven @ only ~65% of their rated current (Rated Current = 950mA....Peak efficiency//Target Current = ~600mA) they are relatively immune to destructive run away from thermal drift and normal grid line variations.....Which only leaves "surge protection" for voltages over 204V.....a traditional inductor/capacitor post rectifier filter is certainly worth the effort, but installing a "whole house surge protector" on the mains and then routing the power through a smaller surge protector should ensure that transient spikes are significantly muted before reaching the rectifier and its filters.....
The existing F-Lights are on five separate breaker-circuits and wired with 6-10 lights per circuit, so my thought is to build a rectifier for each existing circuit with fairly robust filtering and then add second order filters at each fixture in the circuit followed by a 1A Circuit Breaker or fuse and a 180V (Standoff Voltage) TVS as the final line of defense (which should trip the breaker/blow the fuse if a voltage spike makes it past the primary surge suppressors, secondary and tertiary supply filters) While all of this may sound like a lot, the actual cost of materials for a one-time short run for the ~40 fixtures is actually almost negligible....
The Elephant in the room is the complete lack of galvanic isolation.....but this is obviously already true for the 120V mains run to the existing lights....and with a 1A circuit breaker/fuse at each fixture the potential hazard is lower than that of the existing fixtures.....
A dark and dangerous path.....I would love some thoughts on why I shouldn't proceed to build/test a prototype....Intuitively the lack of galvanic isolation worries me, AND the idea of operating LEDs w/o at least passive current limiting is troublesome.....but the math would SEEM to suggest the circuit (or lack there of) will operate nominally under a fairly large range of conditions....And I can't see any way a "real driver" would increase safety or efficiency.....
Thanks in Advance,
Fish
chopnhack
Apr 28, 2014
1,576
I had a similar thought on them and discovered that they were commercially available... imagine my shock LOL. I have come to the electronics world a novice too late in the cycle to contribute much, but like you, I have a good idea once in awhile!
The TVS is a great idea - I would install one regardless of what you do for the lighting, they are a God send with all the electrical appliances in our houses now. I installed one some years back and it blew in a lightning storm :) Probably saved me some $$$. PoCo came out and took me off the grid while I wired in a new one.
I don't necessarily follow your logic on isolation though - the mains run to the lights is a given, no isolation, but that is covered by building codes and is considered safe so long as you don't put a nail through one ;-) Ok, so far. As for installing a 1A circuit breaker? You are no more isolated from mains, just limited to 1A - which circuit breakers are notorious for not tripping at the rated value, there is a period where the amperage is exceeded temporarily. Even so, I think 1A at mains voltage is probably more than enough to kill. Inside from the ballast to the tombstones, I guess you could use an isolation tranformer, but I am not sure what that would do to your budget.
Would a 200v 5w zener diode serve as an overvoltage clamp?
You mention that fitting the fixtures is rather negligible - can you tell me how you are managing that? I was curious what kind of carrier you were going to use to span the 8'. The LED's are cheap for sure, but the other items is where I figured it was not economical to build your own. I would love to hear your thoughts!
At $38/tube, you might be able to build them cheaper, but you might also want to buy one and take it apart to reverse engineer it. Check out this link.
TTYL
Fish4Fun
Aug 27, 2013
481
chopnhack.....really? $38/Tube? Why am I ALWAYS the last one to get the memo? .....About 7 years ago I replaced the 4ft F-Tubes in my display freezer.....4 total tubes.....I paid close to $400 for them....I was just assuming the 8ft F-Tubes would be STUPID expensive...and likely they were...7 years ago, LOL. Guess I should have figured if LEDs had dropped in price by 99% that the fixtures would have come down with them....LOL!
@fitting the fixtures is rather negligible......Really pretty simple....leave the existing fixtures in place.....install the LEDs in the "covers" that hide all the wiring.....just use heat sink compound "glue"....then the old fixture becomes a giant heat sink :) Not that it really matters any more, lol
@I don't necessarily follow your logic on isolation though.....the existing ballast to the lights will deliver more than 1A ....my thought was if "fused" the line wouldn't be any **more** dangerous than the existing lights....Again....moot point.....
@5W zener....perhaps, but a TVS is designed specifically to suppress voltage spikes...they are just about as cheap as a zener but can handle blah, blah k-joules for brief periods...I think they are essentially a scr/triac triggered by a zener....EXCEPT they stop conducting when the over voltage condition subsides...not exactly how that trick works....http://www.digikey.com/product-search/en?vendor=0&keywords=5KP190A&stock=1 ....and yet another moot point....
@38/Tube I don't have any desire to mess with it, lol....THANKS! I will do some research:)
Fish
I've just been involved in replacing 20 or so 4ft fluros that are about 4m off the ground.
2 were replaced with LED tubes, the rest with $3 tubes. The difference in brightness and estimated life is not significant. The LED tubes are 20W cf 36W for the fluros.
It will be interesting to compare them as they age (which is one reason why there are a couple of LED tubes up there).
I wouldn't regard them as cost effective right now, although I haven't calculated the cost of energy saved. They do switch on much faster though :)
OK, I just did a quick calculation. The break-even point for cost is at around the 15,000 hour mark -- depending heavily on the price per unit you're being charged.
chopnhack
Apr 28, 2014
1,576
How many ballasts will fail before the 15k hour mark?
