three phase rectifier voltage issue
alal
Jun 21, 2019
6
I captured an output voltage waveform of the three-phase rectifier system. Could anyone help me understand what might be the cause of the little spikes?
Minder
Apr 24, 2015
3,561
Is this supplying any load, or just a 3ph rectifier?
What is the source of the 3ph?
Where are you referencing it to, the wave form is not a normal rectified pattern for 3phase.
The should have a 120deg overlap for every cycle.
M.
alal
Jun 21, 2019
6
M.
It has dc crane and dc led lights on the system. The crane load is on and off. When the led lights are on, the problem exaggerates. I'm trying to figure out the source of the problem, the rectifier or the led driver. The source of the 3ph is from a three-phase ac transformer.
Minder
Apr 24, 2015
3,561
I added a edit in the mean time, as I said the wave form does not look normal other than the spike.
M.
Minder
Apr 24, 2015
3,561
It appears to be more 1phase than a typical 3 phase output.
M.
Minder
Apr 24, 2015
3,561
You should be getting a 360deg approx 5% ripple sitting on the top.
What is the nature of the rectifier and where is your reference point from?
M.
alal
Jun 21, 2019
6
M.
The time division is 7.95 on the x-axis. I counted the peaks based on this time.
Alec_t
Jul 7, 2015
3,821
Are you sure the polarities of all the rectifier diodes are correct?
alal
Jun 21, 2019
6
I think the polarities are correct. I run a simulation with the wrong polarity, the waveform does not look like the measured.
alal
Jun 21, 2019
6
I found out it is actually half controlled rectifier, so 3 diodes, 3 SCRs. The waveform is normal.
