tic tac on transformer chopper from satellite receiver
nene05
Oct 8, 2022
hello everyone i have a problem with my satellite receiver there is a noise coming from the transformer chopper
circuit and receiver goes on and off
Alec_t
Jul 7, 2015
3,820
Welcome to maker.pro.
The symptom suggests that the receiver has developed a fault which draws excessive current from the power supply, which is then going into self-protect 'hiccup' mode . This involves it shutting down, waiting a bit, starting up again, sensing an overload condition is still present, shutting down .....etc.
It would help if you could post at least the make and model of your receiver, together with a link to any technical data for it.
Externet
Aug 24, 2009
944
Disconnect the antenna LNB coaxial connector and check if the restarting 'tic tac' persists. If not; the coaxial cable, connector or LNB is faulty.
