Time to Digital Converter
Lizwi
Nov 9, 2023
18
Hi
I am doing a masters project in electronics.
My project is titled "Time to Digital Converter"
I am trying to understand the working of a delay line:
1. How does a delay line differ from a counter?
2. What is the need to delay a start signal and how does that improves the time resolution for a TDC?
Delta Prime
Jul 29, 2020
2,996
A masters? I would love to have that sheepskin. Good luck to you.
Here's a snippet.
Delay line based time-to-digital converter: This is a very primitive TDC and involves a delay-line which is used to delay the reference signal. The other signal is used to sample the state of delay chain. Each stage of delay chain outputs to a flip-flop or a latch which is clocked by the sample signal.
danadak
Feb 19, 2021
1,104
1) A digital delay (counter) needs a clock and some timing function to sync.
It has / adds jitter to the timing event. Commonly used to wait for data to
settle at some input, like a flip flop, before attempting to clock it in. Its the
whole issue of metastability -
A non amplified analog delay line is just passive RLC, jitter is reduced to dealing
with just thermal noise of R's and any other noise generating phenomena, like
vibration effects on LC components. An analog delay line is a distortionless
construct that propagates analog signals.
Regards, Dana.
AnalogKid
Jun 10, 2015
3,058
Isn't this just an interval counter? Or a shift register? The delay line approach is conceptually more simple, but the precision will be low. What time resolution does the output have to represent?
Also, this seems like a pretty simple task for a masters project.
ak
14,317
Isn't that a clock?
Help us understand your problem by describing it in more detail. A delay line per se is not a time to digital converter. As the name says it simply delays an input signal such that it appears at the output some time later. This can be done in a variety of ways, analog digital, acoustically and even electromechanically.
Delta Prime
Jul 29, 2020
2,996
Welcome to Maker Pro! :oops:
Here's a little snippet from the link below.
The first time-to-digital converters were developed for scientific and research purposes. They were considered a combination of a time-to-analog (TAC) and analog-to-digital (ADC) converter.
