timed circuits with electromagnets
PaulBrooke
Nov 20, 2017
Hey guys,
I'm wanting to make a circuit with 4 electromagnets running on a 12v power supply, but I would like each electromagnet to turn on and off one after the other, so that iron fillings move on a surface above from the first to the last electromagnet.
Is there a way to do this manually or with Arduino?
Thanks!
Paul
14,317
Welcome to EP.
Manually: e.g. by using a rotary switch with four positions. By moving the dial on the switch the magnets become subsequently powered.
Using Arduino: Easily. You'll need drivers (transistors) to power the magnets as the Arduino cannot provide enough output power (unless your magnets are very weak). Connect each driver to one output of the Arduino with proper series resistors to limit base current. Activate and deactivate the outputs in the proper sequence by a short program.
Minder
Apr 24, 2015
3,561
Do you want variable rate?
If using a PIC or Arduino, you could look at logic gate Mosfets, no base currents.
M.
AnalogKid
Jun 10, 2015
3,058
If using a CD4017 Johnson counter, no programming.
What are the electromagnet coil resistance and voltage?
ak
WHONOES
May 20, 2017
1,242
I agree. Using a Johnson counter should be easy, just need a frequency source again easy, and mosfets on the outputs.
