tl431 calculations
docb
Feb 11, 2010
131
Using a TL431 to limit a 29v source to about 5v.
I see I calculate the two divider resistors to set the vref.
There's one other resistor that limits the current.
Any suggestions how to determine that value?
dorke
Jun 20, 2015
2,342
Are you talking about Rsup?
What is the load current ?
docb
Feb 11, 2010
131
There's a current limiting resistor before the voltage divider in the sample circuits. I don't know if that what you mean by Rsup.
Load current about 20-30mA.
The minimum current through a TL431 is around 0.5mA from memory, but let's make it 2mA.
Thus, there are three places for the current to go:
1) through the load (30ma)
2) through the tl431 (min 2mA)
3) through the voltage divider across the TL431.
The TL431 has a reference voltage of about 2.5V, so the voltage divider for 5V is simply 2 resistors of the same value. Let's use 10k.
So 5V across 20k is 0.25mA
The total current is 32.25mA.
The series resistor needs to drop no more than Vin - Vout at 32.25mA.
If we want the circuit to operate down to 10V input voltage, then the required series resistance is (10 - 5)/0.032225 = 155 ohms (let's say 150 ohms).
If the maximum input voltage can go up to 14V and the load is disconnected, then the current through the 431 will be ((14 - 5)/150) - 0.00025 = about 60mA and thus the dissipation of the TL431 will be 300mW and the series resistor will dissipate 0.54W
under these circumstances the 431 will probably need a heatsink, and the series resistor should be rated at 1W to be safe.
Change the figures to suit your application. OOPS I used 12V as your source voltage, so you'll have to recalculate anyway. do that and we'll check you got it right.
docb
Feb 11, 2010
131
"The TL431 has a reference voltage of about 2.5V, so the voltage divider for 5V is simply 2 resistors of the same value. Let's use 10k."
If it's 10k each, then 1 x r1/r2=2.5v. Shouldn't it be a 20k and 10k, so 1 x r1/r2=5v?
dorke
Jun 20, 2015
2,342
Vout=Vref(1+R1/R2)
for R1=R2 you get
Vout=Vref*2=5V
So R1=R2=10k ohm is correct like steve suggested
Rsup is the series resistor .
In order to calculate it you need to know the following info.
Maxiload=Max load current (Not "about")
Miniload=Min load current (Not "about")
MaxVsup (non regulated voltage)
Min Vsup (non regulated voltage)
once you know the above
IakMin =1ma (from data sheet) ;
RsupMin=MinVsup/(IakMin+Maxiload+5/20K)
IakMax= 100ma (from data sheet);
The maximum AK current in the circuit is
Iakmax=MaxVsup/RsupMin should be smaller than 100ma
docb
Feb 11, 2010
131
I see. The divider is calculated so there's always 2.5v at REF?
That sets the Vo, and the Rsup is for current..
