Tonghui TH2821A LCR Meter
Mike
Here's something that may interest some folks here. I just got my new
Tonghui TH2821A LCR Meter, and I'm starting to become quite impressed.
After some screwups due to a discharged internal battery and not reading
the instructions, it is starting to give some really impressive results.
5 digits resolution on 1000uf caps, 4 digits on iron-core inductor,
miscellaneous resolution on 30k resistors (I haven't figured out how to
measure resistance yet, but it should be very easy:)
Here's the eBay info:
LCR RCL LC Meter TH2821A inductance Capacitance 10kHz
Price : US $164.93
Shipping : $25.00
Item : 320492041898
It can measure 6 basic parameters: inductance L, capacitance C,
resistance R, impedance Z, dissipation factor D and quality factor
Q.
It has measurement accuracy of 0.3% and 4-bin sorting.
Applied complete 5-terminal measurement configuration solves problem
of measurement for equivalent series resistance and capacitor with
small dissipation that other portable LCR meters can't solve. It can
replace general low-frequency LCR meter.
Only portable LCR meter at home
Large LCD display
Measurement frequency up to 10kHz
Basic accuracy: 0.3% with resolution of 0.01%
5-side measurement technology to provide accurate measurement of ESR
and loss
Sweep Clear Function
battery and external power supply power supply
fourth gear sorting
Measurement Signal
Signal Frequency : 100Hz 120Hz 1KHz,10KHz
OutPut Impedance : Dependent on range
Test level : 0.3Vrms
Measurement display range
R : 0.0001Ohm ~ 99.999Ohm
C : 0.01pF ~ 9999uF
L : 0.01uH ~ 9999H
D,Q : 0.0001 ~ 9.9999
?% : -999.99% ~ 999.99%
Comparator
Comparator : 4bins: NG, P1, P2, P3 with beeper alarm
You can also get smd tongs:
LCR METER-SMD/CLIP,TWEEZERS,TH26029 FOR TONGHUI,
US $36.00
Item : 350502463639
The manual is dated November 2005, 1st Edition Rev 1.0.0
"http://www.pinsonne-elektronik.de/media/daten/TH2821A Operation%
20Manual.pdf"
Specifications
"http://www.ekt2.com/_files/40 TONGHUI TH2821.pdf"
Datasheet
"http://www.aet.com.pl/Portals/0/katalogi_pdf/maszyny_zalewy_impregnaty/m
ostki_rlc/th2821.pdf"
You can also get the TH2821B, which goes to 1KHz
Item: 350501591362
Price: US $136.00
The only problem so far is they shipped a 220VAC adapter, which does not
work on 120VAC. After some discussions, they shipped a universal 100-
240VAC adapter which should work anywhere. If you want one, be sure and
tell them to ship the universal 100-240VAC adapter. But they are very
nice to deal with and you should have no problems.
For the performance and price, I don't think you can beat this anywhere.
I especially like being able to measure ESR of large electrolytics, since
I have a lot of eBay boat anchors that need some care.
So far the performance is excellent. I'll post if I come across any
surprises.
Regards,
Mike
Mike
to measure resistance yet, but it should be very easy:)
The resistance measurements are now OK once the internal battery is
charged. This issue is mentioned in the manual. The unit comes with the
battery discharged, so you just have to wait until it is charged before
starting to play with it.
It gives 4 digits of resolution on a 30k resistor. This is adequate for
most ordinary needs.
Altogether, I'm very pleased. It has already identified a bad electrolytic
in a circuit where there are several that could be causing the problem. The
rest are fine.
Mike
Mike
The TH2821A appears to be discontinued, but there may still be some stock
left on eBay.
The replacement is the TH2822C, which goes up to 100KHz and offers
averaging, 40,000 counts, 16 hours operation on internal battery, TH2822C
has optional rechargeable batteries, Standard Mini-USB interface, etc.
Here's the feature list:
* Basic measurement accuracy: 0.25%
* Gorgeous dual-color cast shell
* Maximum test signal frequency: 100kHz (TH2822C)
* 40,000 counts for primary parameter, D/Q resolution 0.0001
* Typical ultra-low consumption : 25mA
* Battery capacity: TH2822/TH2822A continuously used for 16 hours
* TH2822C rechargeable batteries are optional
* Innovatively compatible terminal configuration : 5-terminal test
slot and 3-terminal banana jack
* Intelligent Auto LCR function
* Measurement speed up to 4 meas/sec
* fast automatic range switch design
* Constant output impedance: 100 Ohm
* Percentage display and 4-tolerance comparator: 1%, 5%, 10%,
20% (20% not available for TH2822)
* Automatic OPEN/SHORT correction detection
* Data Hold, Max/Min/ Average recording
* Utility function configuration and current setup recovery after
power-off
* Standard Mini-USB interface, SCPI compatible
* Firmware update through Mini-USB interface
* Free FastAccess communication software on our website
The web page is
http://www.tonghui.com.cn/en/goods/index/250.html
The TH2822C are vailable on eBay for around $474.70
It looks like the TH2821A is a pretty good deal for the price, if you can
still get one:)
Mike
John S
left on eBay.
power-off
The web page is
still get one:)
Mike
You talked me into it, Mike. The specs look super to me and I've been
needing something like it.
Do you get probes with it so you can test components on a populated board?
Thanks for the find.
John S
Mike
been needing something like it.
populated board?
Which one are you getting - TH2821A or TH2822C?
The SMD probe I mentioned earlier is for the TH2821A. It is
available on eBay:
LCR METER-SMD/CLIP, TWEEZERS, TH26029 FOR TONGHUI,
Price: US $36.00
Item : 350502463639
It won't work on the TH2822, but they should have something that
does work.
For populated boards, of course you have to watch for other
components in parallel. But the measuring voltage seems to be too
low to turn on silicon junctions, so it should work OK in most
situations.
I was afraid of accidentally testing a charged electrolytic, which
is how I destroyed my last capacitance meter. So I tried adding a
fast silicon diode in parallel with a large electrolytic.
As far as I can tell, it has little or no effect on the reading. But
it makes the instrument go nuts when there is no electrolytic
capacitor to measure. I will make a little test fixture that adds
two fast 3A diodes back-to-back in parallel with the test probes to
try to avoid making the same mistake in the future.
I find sometimes the reading on the TH2821A fluctuates a bit. You
have to find the correct test frequency for the component you are
trying to measure.
I would really like the ability to average the readings, which is
provided in the TH2822C. But the price is way more than I am willing
to pay.
Once it gets to that level, I seriously start thinking of making my
own unit. With the components available to us these days, it should
be possible to beat the performance of almost anything on the
market.
For example, there are two vector network analyzers available on the
web that you can build yourself. Both are in the Yahoo forums, and
they seem to be very good instruments. But already there is a much
better version of the DDS than the one they are using. That should
improve the performance substantially.
There is also a spectrum analyzer you can build yourself. But I
happen to have a 8566 so that is not too interesting at the moment.
The only problem is if the 8566 dies and needs some unobtanium part.
That already happened to a HP 8505 network analyzer that I bought
new, and was discontinued the week after I paid cash for it. It ran
for a number of years, then it died. It would have cost too much to
get it repaired, so I just put it in a dumpster and promised myself
I would never buy another expensive instrument. Either get it on
eBay for pennies, or build it myself.
Ultimately I would rather have my own stuff. It will take much less
room on the bench, have usb interface for control, and be much
easier to repair or upgrade as time goes on.
Regards,
Mike
P E Schoen
About four years ago I purchased a similar unit, the MCP BR2822 LCR
http://www.mcpsh.com/BR2821 BR2822.html
I paid $250 for it and except for some problems with the battery, it seemed
OK. But I have not used it much. I think I got it from these guys:
http://www.multimeterwarehouse.com/BR2822.htm,
who now want $349 for it. Amazon has it for $300.
http://www.amazon.com/MCP-BR2822-Professional-10KHz-Digital/product-reviews/B000TYUZM0
I also bought a $50 LCR that I use for everyday purposes:
http://www.amazon.com/Sinometer-MS8222H-Digital-Multimeter-Meter/dp/B000MFIDC0.
It's OK, but sometimes I have to fiddle with the switch and/or the leads to
get continuity.
I'm waiting for delivery on:
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=190450842291&ssPageName=ADME:L:OU:US:1123
and
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=190452347958&ssPageName=ADME:L:OU:US:1123
I'm considering the following unit:
http://www.ebay.com/itm/320780815383?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
or maybe this:
http://www.ebay.com/itm/330633195250?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Paul
Mike
seemed OK. But I have not used it much. I think I got it from these
guys: http://www.multimeterwarehouse.com/BR2822.htm,
iews/B000TYUZM0
That looks identical to the TH2821A!
0MFIDC0. It's OK, but sometimes I have to fiddle with the switch
and/or the leads to get continuity.
Yes, I have a bunch of dmms. Some measure capacitance, but none measure
ESR. You need that to weed out the bad electrolytics in eBay boat
anchors.
For the function generator, I've pretty much decided to go ahead and make
my own using a DDS. You can get microhertz resolution, 0 to 250MHz sine
waves, and USB interface. I think you can get frequency sweep and other
functions, and add your own limiter for square waves. Put two in the same
box for intermodulation testing and mixer development. Add external
filters for high purity sine waves for harmonic distortion. Run it off a
GPS-stabilized reference for the ultimate in frequency stability.
The main thing is you can't predict what you may want to do, so having
the flexibiity to modify your own generator is much better than getting a
commercial unit that may not have the fundamental accuracy and stability
you need. You might be reluctant to modify a commercial unit, or maybe
you don't even get the schematics. But if it's your own, that is no
problem.
Mike
John S
TH2821A
available on eBay:
Price: US $36.00
Item : 350502463639
Thanks. I'll look into it.
John S
John S
available on eBay:
Price: US $36.00
Item : 350502463639
BTW, these are also available for those large, TH electrolytics already
on the board:
Item 320702317637
Cheers,
John S
Mike
on the board:
Item 320702317637
Cheers,
John S
Good News - those came with the TH2821A.
I have been trying to figure out how they make them into Kelvin contacts.
The contact pads are two sided pcb. I think they may use one side for the
exciting signal and the other side for the sense. It appears they do the
same with the clips, since there are separate leads going to each side.
I put a thin dab of vaseline on the contacts. That provides a bit of
lubrication to minimize wear. It also removes the surface oxides and grime
and allows a true metal-to-metal contact. This reduces the contact
resistance by a factor of ten and stabilizes it. Old radio engineer's trick
from the 1930's
Mike
Mike
There are numerous eBay vendors that still offer the TH2821A. The prices
vary quite a bit, but it looks like dealexcel-com has the best offer at the
moment. They want US $185.65, but the shipping is now free. That's where I
got my unit, but the shipping was extra.
If you are interested in getting one, I'd go with them. They already know
about the problem with the 220VAC adapter not working in the US, and they
shipped a replacement that goes from 100VAC to 220VAC so it should work
anywhere.
They send the Kelvin clips with the unit, so you don't have to buy them
separately. They also handle the smd probe, so you can combine the entire
order in one package.
Mike
ehsjr
anchors.
You can build a go/no go ESR "meter" that'll find the bad 'lytics
for next to nothing. Worth doing, unless you (psychologically)
_must_ have a "real" esr meter.
Ed
Mike
populated board?
Sorry, John. I completely missed your question for some reason. Just
to confirm, the TH26027 Kelvin test cable probe comes with the
TH2821A. It is listed as an accessory on page 4 of the Operator's
Manual:
"http://www.aidetek.com/New_products_info/Datasheet/tonghui/2821A.pdf"
and also listed in the datasheet:
"http://www.aidetek.com/New_products_info/Datasheet/tonghui/2821data%
20sheet.pdf"
I checked the continuity from the two-sided contact pad to the test
clip. The connections are all individual and separate from each
other, so it is a true Kelvin connection all the way to the
component.
Pretty good for a $185US instrument!
Just make sure you get the Universal 100-220VAC adapter.
Mike
John S
Manual:
Well, I already bought another set. But, that's okay.
20sheet.pdf"
component.
Mike
Maybe I'll send him an email to remind him.
Thanks for the clue.
John S
Mike
You talked me into it. I can think of several projects where this would
come in handy. You can never tell when these things will disappear, so I
got a set also.
Thanks for the pointer!
Mike
John S
I suspect Mike and John are bots.
I will now test.
Hey Mike!
You pathetic blob of useless DNA that didn't get aborted fast enough
with a Black and Decker router.
You're a parasitic garbage making mindless consumer robot that will die
unhappy in your own filth.
You're a fat ugly unwanted unsuccessful unloved uninteresting cockless
guy who lives in a basement with his psychotic crack addicted mother.
I had a tiny amount of respect for you until you pulled this crap out of
your ass.
John S
I do wonder which was more offensive. Being accused of being a bot or my
test insults.
I hope you die wondering. Soon.
Martin Riddle
I think it is a Bot, probably Japanese origin from the English and
grammar it uses.
Cheers
josephkk
I will now test.
Hey Mike!
D you are a brain dead twit.
John S
I use the term 'Bot' cause I'm don't know a word for when someone makes
a fake usenet discussion for the purpose of advertising.
It's a form of spam. Fake discussion spam?
It's a method of dodging user name filtering or I think it's called
ploinking.
Regular spam gets quickly added to filters.
I suspect Mike is John S's puppet.
I could be wrong.
You are. And, josephkk is right; you are a brain dead twit. And what the
hell business is it of yours?
