Toshiba CX36H60 -no vertical raster
sokar9
Sep 17, 2011
Have a Toshiba color tv model CX36H60 Chassis TAC 9813 that started loosing the vertical raster intermitently.
Fixed several cold solder joints and worked ok for a while.But now the vertical raster is totally gone.
Need schematic,components location chart or any idea about fix for this problem.
Regards
shrtrnd
Jan 15, 2010
3,903
Horizontal output transistor.
Check the resistors and capacitors connected to it in case they were also damaged.
sokar9
Sep 17, 2011
Cold solder joints
I pulled the whole TV printed ckt bd out (AGAIN)and inspected troughly the solder joints and found several dubious joints.Also found a loose capacitor by the (vertical) ??output transistor and resoldered.Last but not least resoldered all 3 big IC's on the board.All OK now.
