Toshiba SD-P1600 DC Jack Broken!
Billy Gilbert
The DC jack on the side of my Toshiba SD-P1600 has a small barrel in
its center, and that barrel has broken off, rendering the machine
unchargable and therefore unusable.
And I'm having a very difficult time finding a replacement jack. I'd
even look for a broken machine in the hope of replacing the whole
board, so I won't have to solder.
Got any idea of source or even part number for an item like this? No
luck at Mouser, so I'm stymied.
Samuel M. Goldwasser
You should be able to find a broken Toshiba portable DVD player
on eBay for less cost than the minimum order at Mouser, even if they
did have the DC jack. Since the same DC jack is used a number of
Toshibal DVD players and other items, you don't have to find
the exact model. The most common is probably the SD-KP19.
The mainboards are often fine with the problems being in the DVD drive
or display, but not always, and thus even if you find a broken SD-P1600,
it may be necessary to transfer the DC jack.
The other option is to wire in a more conventional DC jack and change
the plug on the adapter.
Please note that in either scenario, removing and replacing the mainboard
is not something for a total novice. There are many tiny screws and
opportunities to rip wires off of connectors.
sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
Billy Gilbert
Thanks for the suggestions -- it only makes sense that Toshiba would
use that jack in more than one machine, but I wasn't thinking in that
direction. I'll keep pursuing that for a while before looking at
changing the jack and plug.
I took the mainboard out (and put it back in) already just to assure
myself that it's possible with my fat fingers.
BG
Billy Gilbert
I had the following conversation with a Toshiba rep:
Me: I'm calling to find a nearby repair center for the SD-P1600.
(We establish that it's long out of warranty coverage.)
Rep: That unit gets a depot repair. I'll give you the address, and
they'll fix it for you.
Me: Okay. Can you tell me how much it would cost?
Rep: Oh. Yes. That would help, wouldn't it?
Me: It would. Is it a flat rate kind of thing?
Rep: It is. The cost is $114.95, which includes return shipping.
Me: I can buy a brand-new unit for $95.
(Pause.)
Rep: Can I set you up for a repair, then?
Me: Uh, no. I'd have to be out of my mind to do that. I'd have to be
insane.
Rep: Thank you for calling Toshiba.
BG
Billy Gilbert
Finally found the DC jack I need, but it was a grueling search. After
striking out on learning the part number, I started looking at
Toshiba's authorized parts-supply websites, and Vance Baldwin
Electronics had a PDF of the unit's service manual available. I pulled
the part number off the schematic and found it, albeit with a
different stock number, at the Baldwin site.
Now to see just how ominous its back-order status turns out to be.
BG
