Touching halogen bulbs
Andy
Is it too late to clean a quartz bulb if I have touched it during
installation?
I will have already deposited skin oils and grease.
David Lee
Andy wrote...
installation?
You can clean the envelope using alcohol - surgical spirit or iso-propyl
alcohol, as available. Then don't touch it again!
David
V
Victor Roberts
installation?
No. Just clean the bulb surface.
Vic Roberts
http://www.RobertsResearchInc.com
To reply via e-mail:
replace xxx with vdr in the Reply to: address
or use e-mail address listed at the Web site.
This information is provided for educational purposes only.
It may not be used in any publication or posted on any Web
site without written permission.
Robbie McFerren
I'm thinking at most a slightly shortened life span of the lamp.
TKM
installation?
Assuming the lamp is a general lighting lamp -- no big deal. Clean it
(alcohol or window cleaner will do), wipe it dry with a tissue or clean
cloth and turn it on.
Or, just forget it unless there is some sophistocated optical system
involved. The worst that can happen is that the surface of the quartz will
diffuse slightly. Lamp life will not be affected.
Terry McGowan
David Lee
[email protected] wrote...
Grease on the halogen lamp may cause explosion as it gets hot and
blackens the grease, which then heats up more than some other points on
the glass, causing "unbalanced" thermal expansion resulting in
shattering of the glass.
You would probably need to apply the grease with a butter knife! In my
experience contamination tends to lead to de-vitrification of the quartz
envelope and early failure but I've never had one burst. I always believed
that it was the salts from your fingerprints that did the real damage -
diffusing into the silica - but of course you need to dissolve the finger
grease with alcohol before you can wipe off all the salts.
David
TKM
believed that it was the salts from your fingerprints that did the real
damage - diffusing into the silica - but of course you need to dissolve
the finger grease with alcohol before you can wipe off all the salts.
David
The early failure and/or rupture of halogen lamps contaminated by finger
prints or grease are widely-held notions; but in several decades of product
service experience with a major lamp manufacturer and the inventors of the
halogen lamp, I've never seen any evidence of such a problem with general
service halogen lamps. Sure, dirt can cause some fogging (devitrification)
of the quartz surface; but that's a long ways from bulb softening and
failure.
I'd be interested in hearing from anyone who (really) has had or seen such
problems -- again emphasizing for general service lighting lamps, not
stage/studio, reprographic or other special purpose halogen lamps that are
designed closer to the limits of the materials.
Terry McGowan
TKM
video guy - www.locoworks.com said:
What did the producer say when you called a cut so that you could
invert the globes?
Stage/studio lamps are certainly more likely to have problems such as you
describe. For one thing, the filaments are operated at higher
temperatures -- 3200K vs. 3000K, for example.
It's normal for the quartz envelope to glow after switch off; but not to
bulge. That says the temperature of the quartz is at the softening point.
Not good.
I wonder if the reflector was refocusing the energy back onto the lamp in
that particular case. Sometimes when a spherical reflector section is used,
that happens.
Terry McGowan
Z
Zak
Ian said:
I had several 500W linear floodlights fail.
I've had one fail after a 1 meter fall while on (220 volt tube).
It kept working and I placed it back. I thought: hmm, these are fairly
string. About 30 seconds later it went, I believe taking the house fuse
with it. It had spewn out its filament over quite a distance.
Please keep the fittings grounded/earthed.
Thomas
