Toyota Order Picker PCB
TRoss22
Aug 4, 2021
5
I am trying ong to identify what this component is and what it's purpose is on the PCB. I am going to take out the board and replace the component once I properly identify the piece. Any help would be greatly appreciated.20210803_165819.jpg 20210803_172411.jpg
Photo too blurry to identify anything but by board marking some kind of capacitor.
What makes you believe it is faulty?
Did you cut it out or did it fall out?
bertus
3,882
For the capacitor, it can well be there is more info on the top.
Post a CLEAR and SHARP picture.
Bertus
TRoss22
Aug 4, 2021
5
It was knocked off when they were replacing a drive motor. Here's a better picture hopefully20210804_071335.jpg
bertus
3,882
The picture only gives us that the capacitor has a voltage rating of 50 Volts.
As I asked before, is there any text on top of the capacitor, like in the picture below:
Bertus
bertus
3,882
OK, the 334 tells me te capacitor has a value of 330000 pF = 330 nF = 0.33 μF
The K tells me the tollerance is 10 %.
The 50 Volts on the other side is the maximum working voltage.
Bertus
TRoss22
Aug 4, 2021
5
Thank you very much for the help. Excuse my ignorance on the subject, but as long as I replace it with a capacitor of the Sam values and tolerance then it should be fine correct??
bertus
3,882
As long as the value and tollerance are the same and the working voltage 50 Volts or higher, you will be OK.
Bertus
