Trail cam
t_bell40
Feb 7, 2017
11
I have a wild view trail cam. I opened it the other day and noticed the batteries i put in the day before were leaking. Took home and cleaned all i could out. Put new batteries in and it comes on but, you can't program it and it won't shut off. The off/on switch will turn it on but, not off.
Any thoughts ???
Martaine2005
May 12, 2015
5,318
Perhaps you need to disassemble it more and give it a thorough cleaning.
Martin
Martaine2005
May 12, 2015
5,318
I have absolutely no idea, but the specs only say ‘C’ batteries.
Specifications for Wildgame Innovations Trail Cameras N4:​
Mfg Item Num: N4
Category: ELECTRONICS
Type: Trail Camera
Function: Pictures and Video
Channels: 4.0 Megapixel
Range: 40 ft
Battery: 4 C cell batteries
Screen Type: LCD display
Waterproof: Water Resistant
BackLight: Yes
Color: Black
kellys_eye
Jun 25, 2010
6,512
The case appears to have suffered some physical damaged (dropped?) which may now be manifesting as issues with other electro-mechanical components such as the switches inside it. Show us more pics (inside etc).
Delta Prime
Jul 29, 2020
2,996
Did you check the last photo your wild view trail cam took? Bigfoot is camera shy! He probably messed with the focusing too; it would come out blurry.
t_bell40
Feb 7, 2017
11
There no on board power for memory. So, nvram.
Cleaned with vinegar and followed with isopropyl. Assembling again, 10-12 time. Crossing fingers
t_bell40
Feb 7, 2017
11
I misspoke, there is an on brd battery. NI-MH 2.4v 40 mah. 11-6-23. Not sure if that's an exp. date or not. But now, I'm looking to find a couple of these batteries as there two dime size batteries packaged together.
Any ideas where i might find them ??
Delta Prime
Jul 29, 2020
2,996
unwrap those things and read what is on the button cells...
Or contact the manufacturer they look proprietary to me may have to buy them directly. Unless you know how to tack weld or spot weld, you can buy them separately. Caution if you try to solder them they're going to pop on you.
This is getting ridiculous. Kind of like that! :p
Hurry up and get those batteries in your trail cam cuz I'm going to pay you a visit.
