Transfer function of DDS
Stefan Huebner
Hi all,
I wonder if anyone has figured out the transfer function of a direct
digital synthesizer, from reference clock input to DAC output?
Actually I only need to know whether it has an 1/z behaviour
(integrator type) or linear.
I use a DDS within a PLL loop as frequency divider and have serious
stability problems.
For those who are interested:
An ADF4002 PLL is fed with a 3Vss rectangular reference signal in the
10k-100MHz range. The other (RF) input is tied to one DDS output of a
4 channel synthesizer (AD9959) via a 180MHz 7th order Bessel low pass
filter and a comparator which ensures sufficiently low rise time at
low frequencies. The input level here is 550mVpp. The PFD output is
routed via the loop filter (lead-lag type at 400Hz at the moment) to a
MAX2608 VCO running at 400MHz (370-430 over the full tuning range).
By now, the PLL locks almost when run at a reference of 1.84MHz, the
DDS also set to 1.84MHz and the ADF4002s internal dividers set to 1.
It locks perfectly when the DDS ist set to 3.68MHz and the RF divider
is set to 2.
It will never lock at the design target frequency of 10kHz at the PFD,
realized by divider ratios of 184.
Tim Wescott
Hi all,
stability problems.
is set to 2.
So you're driving the DDS from the VCO? I'd model the VCO as something
that takes voltage and integrates it to phase, I'd model the DDS as a gain
stage (with gain << 1), and the phase detector as something that takes
phase difference and turns it into a voltage. The summing junction would
be buried in the phase detector.
Are you taking the division ratio into account when you're calculating
your loop filters?
Tim Wescott
Control systems and communications consulting
http://www.wescottdesign.com
Need to learn how to apply control theory in your embedded system?
"Applied Control Theory for Embedded Systems" by Tim Wescott
Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
V
Vladimir Vassilevsky
Stefan said:
Hi all,
DDS transfer function from the clock to the output is no different from
that of the frequency divider. It has a comb FIR action (z[-1]).
stability problems.
is set to 2.
A silly question: You are operating PLL at the very different parameters
of the loop. Are you adjusting the loop gain and the loop filter
accordingly?
DSP and Mixed Signal Design Consultant
http://www.abvolt.com
Marte Schwarz
Hi Stefan,
I noticed your question in d.s.e. before.
is set to 2.
Look @ your control voltage, when the divider ratio is very big. you will
never get a really stable voltage, even with a filter of very high order.
May be it works better, if you feed your control signal into a sample & hold
and hold this value through the time until the next phase arrives.
PLL in such a big frequency range (10 kHz up to 100 MHz???) is a very
strange topic.
Marte
Stefan Huebner
Good to know, I got that point this afternoon and brought it into my
thread on de.sci.electronics already.
accordingly?
At the moment I was hoping I could eliminate all the trouble by making
it slow enough for all frequencies in question.
What, in your opinion, would be a manageable frequency range or ratio
for a PLL using a DDS as divider?
Stefan Huebner
At the moment, I get no control voltage (or almost no) when using a
high prescaler. The PFD output is stuck at the lower end, generating
stochastic output or a sawtooth signal, all of them with an average
voltage far below the VCO tuning voltage for mid frequency.
strange topic.
I know. And I think I'll have to split this range, probably by
switchable loop filters.
As written in dse, I'll draw some diagrams this evening and put them
on a web site.
Thanks so far :)
V
It depends on the performance required. The performance degrades
proportionally to the high/low frq. ratio. Taking the reasonable
assumptions, I would not advise covering the range higher then 100 times
without adjusting the loop parameters. So the 10kHz...100Mhz band should
be split into two subbands at the very least.
Stefan Huebner
For those who already participated and those who will hopefully join
in, I've uploaded the first schematics to:
http://www.engcyclopedia.de/dds_and_pll.pdf
The loop filter is now based upon trial and error, in the mean time I
tried component values based on ADISIM PLL calculations with a lead
and lag filter plus two additional low pass filters.
Being calculated for a PFD clock of 10kHz, it only works stable with
the ADF4002 set to R=1 and N=2 (maybe also for higher N's, but
definitely not for R=N=184 and 1.8MHz external reference clock).
The reference is a 1.8432 MHz XTAL oscillator connected to the SMA
plug on page 2 via a 470R resistor.
