Calculate the transfer function of an OPAMP circuit
mmb1999
Mar 31, 2024
Hello All
I have an OPAMP circuit that its output increase steadily without cahnge in the input. I guess the issue is in the transfer function of the circuit and its stability. I want to calculate the transfer function of my circuit but I do not have any idea about that. Could you please help me to calculte the transfer function?
Delta Prime
Jul 29, 2020
2,996
You describe the circuit but you know what that circuit is called?
Sure I willing help you calculate
All the basic operational amplifier configurations.
But it's your job to know what type of operational amplifier it is...
The transfer function is simply an equation to derive the output of a specific type of operational amplifier.
danadak
Feb 19, 2021
1,104
Signal Flow Graph to get at T(s).
Or attached.
Your circuit will yield a 3'rd order T(s) as shown, not including the OpAmp internal
pole which would give a 4'th order equation. You can solve using node and Kirchoff,
which quite tedious, especially 3'rd order and above. Or one of the tools above.
Regards, Dana.
  • Signal Flow Graph 2 (1).zip
danadak
Feb 19, 2021
1,104
If input to an integrator is left unconnected it will integrate its own bias current,
so you will see a ramp, can be either + or - going ramp, until the output of the
integrator saturates, either close to + supply V or its - supply V.
Regards, Dana.
ramussons
Jun 10, 2014
475
Hello All
What is the output from the Hall sensor? If the Quiescent output of the sensor is not Exactly 2.5 Volts (R1=R2), the output will linearly change to
0 or 5 volts, or
Sensor Quiescent * (R4/R5),
whichever is lower.
