Transformer 240V to 110V how many watts do I need?
EF
Hi I'd appreciate some help.
I have a NiMh battery charger which has AC input of 100~120VAC
50~60HZ, 1.2A.
It outputs at 36VDC, 1.8A.
How many Watt transformer do I need to use this charger in the UK
where we have 240V? The output of the charger itseff is only 65W, but
the input is more, but I'm not sure how to take the phase into
account.
Cheers,
EF
Charles Schuler
50~60HZ, 1.2A.
account.
Power = volts x amps so its about 65 watts. Given allowance for less than
100% efficiency, 100 to 150 watts would be my guess.
K
Ken Taylor
If the input spec's are correct then the input could be up to 144W so,
assuming inefficiencies as you suggest, I'd be looking to maybe 175-200W.
Seems ridiculous for the job but there you go.
Ken
EF
Yeah, it seems over the top when the charger only outputs 65W.
Normally I wouldnt worry and just go for the larger transformer, but
in this instance weight is important as I need to carry the charger
and transformer daily.
Menno
EF
John Fields said:
The input is 120VAC @ 1.2A, so that's 120V * 1.2A = 144VA, not 144W,
which pretty much takes the phase into account.
Assuming the transformer you get is 80% efficient anf you can get
144VA out of its secondary, you'll need at least a 180VA transformer.
Probably the closest thing to that is 200 to 250VA, something like a
Signal transformer DU-1/4. About 12 lb, about $120.
Many thanks for everyone's input.
How many watt is 144VA? I ask because some transformers here have
their rating listed in watts, not VA.
EF
CWatters
50~60HZ, 1.2A.
Can we ask what it's for?
EF
It's to charge a 36V 8Ah battery pack for an electric motor. I'm using
the motor on a bicycle, so have to carry charger with me on the bike,
which is why I wanted to see if a 100VA transformer would be
sufficient, as they are a lot lighter. But from everyone's advice it
looks like it would have to be 200VA.
But I'll follow Jim's suggestion first and open it up to see if it is
switchable.
EF
Jim Gregory
EF
*If* it proves switchable, ie, two primaries arrangeable either in parallel:
115V or in series: 230V, and you adjust it for the higher input, when you
come over here you'll need to fit a new 3-pin plug, 13A (max) type but with
a 2 or 3 Amps 1" fuse inserted... this connector carries an optional ground
connection, as well.
Any electrical shop, DIY store, pound shop, ironmongery sells them.
Michael Redmann
50~60HZ, 1.2A.
If I understand it correctly the charger has 1.2 A at 100 VAC (and maybe
1.0 A at 120 V). Here in Europe we often have wide range devices with
110...230 V input. The input current noted on the device nearly always
referes to the lowest input voltage.
So you need a transformer with output 100 V / 1.2 A with is 120 VA. You
don't need any additional wattage.
Regards
CWatters
the motor on a bicycle.
Interesting. I was also going to ask if the battey is 3 lead acid cells in
series?. If so you might be able to rewire the batteries in parallel for
charging and use a 12V car battery charger.
If they aren't lead acid then the problem is harder. You can buy chargers
capable of charging 36V's worth of NiCad/HiMH cells (eg competition model
aircraft battery chargers) but they tend to be very expensive and most (all)
use a 12V battery as the power source to allow charging on the flying field.
blazeinferno
The output is 65W. Does the charger specify how many watts on the
input side or maybe how much current it consumes on 120V?
If it does specify the current then: Power (Watts=Volts *Amps) and that
should tell you the minimum power your transformer should be able to handle.
If nothing is specified for the input side, then I would estimate the
efficiency of the charger to be at worst 75%. With this approximation, the
input power should roughly be about 65W/0.75=87W. A transformer between 85W
and 100W should be fine. The power for 120V or 240V will still be the same.
The fundamental difference is that current is halved at 240V.
Hope this helps
Ciao
Fern
Don Klipstein
One more thing to worry about when a transformer powers anything with a
rectifier if it also has a filter capacitor: The waveform of the current
drawn by the device. The RMS current can be higher than that of a
resistive load drawing the same amount of power and a sinewave current
waveform - sometimes a lot higher. The RMS current is what will heat up
transformer windings.
Try putting a low value resistor in series with the input of the
charger, and looking at the current waveform on an oscilloscope. Draw it
on graph paper and calculate an approximated RMS value.
Or, you may be able to find an automotive lamp that, when placed in
series with the input of the charger, glows without dropping a lot of
voltage nor burning out. Find out how much current it takes to make the
lamp glow the same way, and that's the RMS current drawn by the charger.
Multiply RMS current by voltage, and that's what the transformer has to be
rated for (often in volt-amps rather than watts).
Michael Redmann
with a rectifier if it also has a filter capacitor: The waveform of
the current drawn by the device. The RMS current can be higher than
that of a resistive load drawing the same amount of power and a
sinewave current waveform - sometimes a lot higher. The RMS current
is what will heat up transformer windings.
The waveform's peak value divided by the rms value is called crest
factor. For pure sine waves the crest factor is 1.414 but input currents
into filter capacitors can easily reach crest factors of 10.
The crest facor is very important if you run uninterruptable power
supplies. For the reason mentioned they have to deliver high peak
currents to your computer's power supplies.
Regards
