Transimpedance v integrating amplifier
Rajinder
Jan 30, 2016
568
I have attached a diagram of a photodiode connected to an opamp, this is an I to V converter or transimpedance amplifier, the current from the photodiode is converted into voltage by the feedback resistor.
I have also seen the same can be achieved using a capacitor in the feedback instead of the resistor. I believe the output voltage is the integral of the input current. I am not sure exactly how this works, can anyone help me to undetstand it.
Also is there any benefit of using one configuration over the other?
Its to be used in a smoke alarm.
Thanks in advance.
14,293
You'll need some math.
The transimpedance amplifier gives instantaneous values whereas the integrator gives, well, integrated value - kind of a low pass filter. Which circuit to use depends on your application:
  • fast response - transimpedance amplifier
  • noise suppression - integrator
