transistor and diode blocking voltages
bumdegi
Can someone please explain to me how transistors can block positive
voltage whereas diodes block negative voltage.
Cheers
H
HardySpicer
Cheers
Depends which way round they are connected and whether they are P or N
type!
Hardy
Jasen Betts
Diodes block reversed voltage due to the way in which the conduct
electricty causing a break in the conductive path when they are
reversed in relation to the voltage.
http://en.wikipedia.org/wiki/Diode
transistors can be used in combination with other electronic parts to
regulate or block over voltage but how they work is more complicated.
http://en.wikipedia.org/wiki/Linear_regulator
http://en.wikipedia.org/wiki/Transistor
MOSFETs (a type of transistor) can also be used like a diode to
protect against backwards voltage.
Further questions of this nature are bast asked in
sci.electronics.basics
Bye.
Jasen
