Cutoff is easy, you just reverse the emitter base junction.
Hi Kevin,
It might be complicated to reverse the junction.
Didn't you know that a transistor will be cutoff if you simply stop its base current? You could do it by shorting its base to its emitter with something like another transistor, or if its emitter is grounded, drive its base feed also to ground.
It is dangerous to have a reverse bias voltage on a silicon transistor's base-emitter junction. The absolute maximum voltage rating for the reverse-biased junction is only 6V to 8V and exceeding it will cause the junction to breakdown with damage.
Hi Matt,
Sure you can use a transistor as a switch for your fan. Simply provide base current to turn it on and stop the base current (like above) to turn it off. A Mosfet is better (and more expensive) but you won't notice the difference unless your fan is enormous.
You can make a simple Pulse-Width-Modulation circuit to control the
speed of the fan, controlled by a temperature sensor. It would operate smoothly and quietly instead of suddenly switching.
