Transistor Identification
Graeme Dennes
1. Would anyone know the manufacturer of small-signal transistor types 9011
and 9014?
2. Any known source to purchase them?
2. Any known equivalents for them?
TIA
Graeme Dennes
Bill Garber
: 1. Would anyone know the manufacturer of small-signal
: and 9014?
: 2. Any known source to purchase them?
: 2. Any known equivalents for them?
: TIA
: Graeme Dennes
Here is an equivalent chart for the 9014. They
may also have one for the 9011 there.
http://www.honeytech.com.hk/old/eq-table_3.html
Hope this is of some assistance.
Bill @ GarberStreet Enterprizez };-)
Web Site - http://garberstreet.netfirms.com
Email - [email protected]
Remove - SPAM and X to contact me
W
Watson A.Name - Watt Sun, Dark Remover
and 9014?
They're general purpose, ultra low cost jelly bean transistors made by
many manufacturers. One manufacturer is Bharat, in India.
http://www.bel-
india.com/BELWebNew/UploadedFiles/Products/Plastic_package.pdf
Do a control-F to find, and enter the number. You should get SS9011,
etc.
You could purchase them, but the companies might want to sell you a
tape reel of 2000 minimum. But at 3 cents apiece, that's only $60 or
so...
Generally speaking, the 2N3904 or 2N3906 or 2N4401 or 2N4403 (NPN and
PNP respectively) would work. It depends on what they are going to be
used for.
TIA
Graeme Dennes
YWIA
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
W
: and 9014?
: TIA
: Graeme Dennes
Gee, that chart is really something. It's like the ECG and NTE123,
one transistor substitutes for almost everything! ;-)
But then, I've seen cheap consumer equipment where almost all of the
transistors are 9014s or ones in that same number series. So maybe
they're right..
See my other followup for a chart of many common transistors and a
brief list of their specs.
Bill Garber
"Watson A.Name - Watt Sun, Dark Remover" <[email protected]>
wrote in message
: In article <[email protected]>,
[email protected]
: mentioned...
: > : > : 1. Would anyone know the manufacturer of small-signal
: > transistor types 9011
: > : and 9014?
: > : 2. Any known source to purchase them?
: > : 2. Any known equivalents for them?
: > : TIA
: > : Graeme Dennes
: > Here is an equivalent chart for the 9014. They
: > may also have one for the 9011 there.
: > http://www.honeytech.com.hk/old/eq-table_3.html
: > Hope this is of some assistance.
: Gee, that chart is really something. It's like the ECG and
NTE123,
: one transistor substitutes for almost everything! ;-)
That is true. I've sub'd many a PP-Jelly bean for another,
I bought a big pack of PNP and another of NPN transistors
at RS and used them in circuits that called for other #s
and they worked. Might have to tweak the size of a resistor
or cap here and there, but no big deal. Maybe 10-20 ohm,
or .02-.1 uF on a cap, but most times you can get away with
one of each type.
: But then, I've seen cheap consumer equipment where almost all
of the
: transistors are 9014s or ones in that same number series. So
maybe
: they're right..
I read something on using NPN in place of a PNP and
vice-versa, but I could not get that to happen. Must
be doing it wrong.
: See my other followup for a chart of many common transistors
and a
: brief list of their specs.
I saw, and $.03 per transistor is not bad at all.
Then again, I doubt I will live long enough to use
2000 of them. Not sure I could use 200 even. ;-)
W
the 9011 in my Towers tranny book is NPN, equivalent is BF368.
manufacturer Hindustan Conductors Pvt Ltd, Gujarat, India. the other isnt
listed in it but i'd say its same manufacturer.
but check this out...........
http://www.ushasemi.com/pdf/Transistors/2SC9011.pdf
and
http://www.ushasemi.com/pdf/Transistors/2SC9014.pdf
and yep i'm pretty certain of the 2sc prefix
Alan
As far as I've seen, the 2SC numbers have never gotten up to that high
a value. But some mfrs may label their products with the C9011, with
no intention whatsoever that the 2S be added as a prefix to the C.
W
wrote in message
[email protected]
: mentioned...
: > : and 9014?
: > : TIA
: > : Graeme Dennes
NTE123,
one of each type.
of the
maybe
: they're right..
be doing it wrong.
and a
Yes, some mfrs offer reels with 5k or more. For some reason the
Mousers and Digi-keys don't want to deal with qtys less than 2k or
more in certain high volume parts. So you may not be able to get 'em
in even as little as 2k qtys.
I've been watching Ebay for discretes, and I see the common ones for
$3 to $5 a hundred, depending on qty. Some guy offers old TO-3 metal
can transistors for $40 a hundred, and no one bid on them. One would
think that he'd know better since he seems top be an experienced Ebay
dealer.
That's what I'd like to ask people here. I see 2N4036 trans offered
for some minimum bid. They claim they're new parts. But on the data
sheet the beta range is 10:1, so one could be buying some picked over
trans, where the gain range is on the low end of that range, i.e. all
one may be getting is the bottom of the barrel. I just wonder if
anyone has had experience with buying these things. I know that the
ones I bought came still attached on tape, so I feel reasonably
certain that they're new, unculled parts.
Bill Garber
wrote in message
[email protected]
: mentioned...
: > "Watson A.Name - Watt Sun, Dark Remover"
<[email protected]>
: > wrote in message
: > : > : In article <[email protected]>,
: > [email protected]
: > : mentioned...
: > That is true. I've sub'd many a PP-Jelly bean for another,
: > I bought a big pack of PNP and another of NPN transistors
: > at RS and used them in circuits that called for other #s
: > and they worked. Might have to tweak the size of a resistor
: > or cap here and there, but no big deal. Maybe 10-20 ohm,
: > or .02-.1 uF on a cap, but most times you can get away with
: > one of each type.
: > : But then, I've seen cheap consumer equipment where almost
all
: > of the
: > : transistors are 9014s or ones in that same number series.
So
: > maybe
: > : they're right..
: > I read something on using NPN in place of a PNP and
: > vice-versa, but I could not get that to happen. Must
: > be doing it wrong.
: > : See my other followup for a chart of many common
transistors
: > and a
: > : brief list of their specs.
: > I saw, and $.03 per transistor is not bad at all.
: > Then again, I doubt I will live long enough to use
: > 2000 of them. Not sure I could use 200 even. ;-)
: Yes, some mfrs offer reels with 5k or more. For some reason
the
: Mousers and Digi-keys don't want to deal with qtys less than 2k
or
: more in certain high volume parts. So you may not be able to
get 'em
: in even as little as 2k qtys.
Some don't like dealing with small time folks like
repair shops and homebrew'rs like me. Sucks, but fact.
: I've been watching Ebay for discretes, and I see the common
ones for
: $3 to $5 a hundred, depending on qty. Some guy offers old TO-3
metal
: can transistors for $40 a hundred, and no one bid on them. One
would
: think that he'd know better since he seems top be an
experienced Ebay
: dealer.
Guess he failed general math. $.40 each is
sort of high, I would think for quantity.
: That's what I'd like to ask people here. I see 2N4036 trans
offered
: for some minimum bid. They claim they're new parts. But on
the data
: sheet the beta range is 10:1, so one could be buying some
picked over
: trans, where the gain range is on the low end of that range,
i.e. all
: one may be getting is the bottom of the barrel. I just wonder
if
: anyone has had experience with buying these things. I know
that the
: ones I bought came still attached on tape, so I feel reasonably
: certain that they're new, unculled parts.
I tend to only trust those that say NEW or NOS,
with a picture of actual packaging, unless I do
truly know what the item is, then only rarely.
I'll buy used eproms and such, and the occasional
vintage test equipment, but they better have a
guarantee of some kind otherwise.
