Transistor Substitute.
electronics_shamim
Mar 21, 2007
77
Sir,
Can anyone help me finding Replacement of Power Transistors;
2SD613 - NPN , 2SD633 - PNP both complimentary pairs
2SD600  & 2SB631 both complimentary pairs
The above are used in power amplifier sections of Sonodyne Model SCR2061. The exact transistors not readily available in India.
Thanks in advance,
Regards
admin2
Administrator
Administrator
Mar 13, 2015
184
[COLOR= rgb(82, 82, 82)]2SD613 NPN [/COLOR]has replacement [COLOR= rgb(0, 0, 0)]BD243C, BD543C, BD801, 2SD866 [/COLOR]BD243C[COLOR= rgb(0, 0, 0)] [/COLOR]KT819G
[COLOR= rgb(82, 82, 82)]2SD633 [/COLOR]is a NPN [COLOR= rgb(0, 0, 0)]Darlington[/COLOR] transistor and has replacement [COLOR= rgb(0, 0, 0)]BD649, BD901, BDW73C, BDX53C BD649[/COLOR]
[COLOR= rgb(82, 82, 82)]2SD600 has replacement [/COLOR][COLOR= rgb(0, 0, 0)]BD139, BD230, BD379, 2SD1684 BD139[/COLOR]
[COLOR= rgb(82, 82, 82)]2SB631 [/COLOR]has replacement [COLOR= rgb(0, 0, 0)]BD140, BD231, BD380, 2SA1184 BD140[/COLOR]
HarryA1
Mar 4, 2009
481
Olaniyi Oladipo
Jun 28, 2020
I have a problem using lm7812 it produced output voltage I connected 48v battery as input voltage but this 12v output didn’t carry just dc fan please what’s the solution to this problem but I remember I do not filter this terminals
HarryA1
Mar 4, 2009
481
48 volts is above the absolute voltage for this voltage regulator: 35 volts maximum:
Zaldy Macayan
Sep 15, 2020
Hello.
Can someone kind enough please provide info about transistor substitute of BC807W and BC817W in TO92 package? They are not locally available but I was hoping a TO92 substitute would be. Will appreciate greatly any reply. :)
Kind regards...
Sekemiat KE
Feb 8, 2022
21
hello
2SD613 NPN  replacement is BD243C
2SD633 replacement BD649
2SD600 has replacement BD139
2SB631 has replacement BD140
