Transistor switching on another voltage supply
Juzzac
Mar 1, 2015
6
Hi, Can someone please help point me in the right direction, I am wanting to switch on a separate 12v circuit with a transistor or similar, the circuit i wish to switch it on from is about 0.2 volts when off and about 1 Volt when on, I would use a solid state relay but can't find one that will switch on with just 1 volt. The circuits don't and can't share the same earth, what would be the best solution ?
Thanks Juzza
cjdelphi
Oct 26, 2011
1,166
Or better still, use an NPN power transistor voltage of 1v is too low for a mosfet , 12v + side to your device to power, eg 12v bulb and the other side to the collector and the emitter tied to ground
that leaves say a 300ohm resistor from the 1v to base of the npn.
cjdelphi
Oct 26, 2011
1,166
Alright fine 2am never read it properly regarding it can't share grounds...
But why?
cjdelphi
Oct 26, 2011
1,166
How?
Then it occurred to me, there's only 1v which is not enough for the optoisolator to light the LED, you'd need the transistor to share grounds with at least a 3vish source to fire an opto at which point why bother and tie grounds with the 12v source ...
Martaine2005
May 12, 2015
5,315
The whole point of isolating circuits is to completely isolate them.. No 'common' either.
It would be an independant circuit controlled by the first low voltage circuit.
For safety reasons no voltage/current can be fed back to the controlling circuit.
Martin
Ps, I will try and find something I read years ago about the light bulb isolator.
Martaine2005
May 12, 2015
5,315
No, it was when I was at college sitting OR failing my part 2 electronics.
Martin
Sorry can't find any of my old city and guilds books yet.
But possibly davenn, Bobk or Colin will be able to shed more light on this..Oh and of course my favourite encyclopedia Howard.
Martin
Minder
Apr 24, 2015
3,561
Set a LM311 to switch over at 1v operate into a 4n25 (25¢), if you need to condition the output for a little more power a 2n7000 will do it up to 200ma.
Total ~ $1.00
Max.
Martin
Colin gave the answer in post #2. It is the same one I would have given.
