Digital transistor for switching application
Akshatha Venkatesh
Jan 14, 2017
145
I found the below schematic in the application note of On semi. Can anyone please explain why two transistors are used , why is the npn transistor used to control the switching of the pnp transistor ? Why not use a single transistor ? Please help.
14,311
This is a high side switch (40 V) with integrated level shifter (control voltage ~5 V only).
You cannot control a switch on the 40 V rail (high side) directly from e.g. a microcontroller output pin (3.3 V or 5 V). The NPN transistor creates the base control signal for the PNP transistor while at the same time decoupling and protecting the microcontroller from the high voltage which would destroy the micorcontroller immediately.
Akshatha Venkatesh
Jan 14, 2017
145
Hi ,
I have another question, when the output from microcontroller is high , the npn is on and pulls the base of the pnp to ground,which turns the pnp on, right ? And when the microcontroller output is low , the npn is off , which in turn the pnp off .is my understanding right ?
Akshatha Venkatesh
Jan 14, 2017
145
Hi, why haven't used the NPN transistor as the switch ?
Alec_t
Jul 7, 2015
3,821
You could do that, but it would be more complicated because the NPN base would need an input (control) voltage 0.6V or so above the voltage you are trying to switch. That, in turn, would need a second supply.
